<font color=“blue”>Rcher,
After looking at it again it probubly will be big enough to kit bash into a sail boat…</font id=“blue”>
NOTES FROM OUR TECH DEPARTMENT
The highly detailed Hobbico Aqua Craft Bristol Bay boat is a
ready-to-run electric fishing boat. Having a fiberglass hull,
detailed deck, and a removable wheelhouse for easy access to
to the electronics.
FEATURES: Hull: Painted fiberglass (Hunter Green,top & Rust color for bottom)
Deck: Wooden, deck detail resembles planks, lifeboat and life
preservers on the outside of the wheelhouse
Sails: Static sails made of cloth with operational lights on mast
controlled by their own on/off switch
Motor: 550 size
Working searchlight, running lights (Red for Port, left side of boat
and Green for Starboard, right side of boat)
Drive System: Direct
Propeller: Brass, 3-blade
Radio: Aquacraft 2-Channel pistol grip with servo reversing,
adjustable steering rate, battery status LED, steering and throttle
trims, and charge jack for optional NiCd batteries, preinstalled
standard size servo and receiver
Speed Control: Electronic forward and reverse
Warranty: 90 Days
INCLUDES: Painted hull, hardware, 550 size motor, 2-channel radio system,
prop, sails, boat stand, instruction manual
REQUIRES: Battery: 7.2V 6 cell flat pack
Charger: Timed or peak for 6 or 7 cell packs
Radio Batteries: 10 AA batteries (8 for the radio and 2 for the
light system on the boat)
SPECS: Hull Type: Fiberglass
Hull Length: 33.5" (851mm)
Beam: 8.8" (223mm)
Height: 29" (737mm)
Prop: 3-bladed (Specs N/A)
Weight: 7-lbs (3175g) (+/-) without the battery
COMMENTS: If wanting to purchase scale crew figures, a reference point for
size would be the door to the wheel house which is 3-1/2" (89mm)
high and 1-3/8" (35mm) wide. The total height of the front of the
wheel house is 5-1/2" (140mm)
Download Attachment: [
bristol bay.jpg](http://www.rcsailing.net/forum1/data/hoghappy/20047114542_bristol bay.jpg)
22.96KB
<font color=“blue”>She may be real close to the scale I’m lookin for too (not that the 2 would have ever met but it just looks better to have them the same scale)! The wheelhouse door is 3 1/2 inches. A scale crew for my ship would be 3 inches tall for a 6 foot man. I like that it has a glass hull VS plastic…a lot easier to work with. I also like that you can motor her to port if the wind dies…a big plus! [:-thumbu]
Let me know how you like it and get some pics up. I may be following you!</font id=“blue”>
Always choose the lesser of the two weevils!
