Hi Anders,
the main reasons for Italian IACC 120 rule changes is that ClaudioV new AC120 design was causing concern in Italy. The outcome of the new rules is that ClaudioV new design is now outside the new rules, however the boat he has under construction is exempt !..as it was under construction under old rule Ver 1.5
I can’t quite work out why one boat is exempt and how the same design is not but I really appreciate that he can race with us, as I really like to see how how this new boat performs.
What I want to say Anders, as your construction started well before the new rules, you will also be exempt under the new “Italian” rules also with inclusion of this new rule B.1.2 which saved ClaudioV new boat under construction.
Boat Eligibility
B.1.2 Every boats made/in construction before these rules (following R.1.5 and previous) will be already in rule.
However this new rule also brought up the LWL debacle as the previous rule Ver 1.5 the max LWL measurement was 1030m. BUT in the Italian rule version it said that water tension (meniscus) was included in the LWL measurement; however, the English version 1.5 of the rules had no reference to water tension.
I was stirring the pot about how no RC class in the world measures meniscus in LWL measurement. Then in a strange twist there were rule change suggestions that wanted to increase LWL from 1030 to 1040 mm (including meniscus) another 10 mm
This was the hammer that made me very suspicious that something was going on to protect existing boats that were outside Ver 1.5 rules and stirred up a hornets’ nest. The outcome final is the following is a summary of changes from rule 1.5 to new rules version 2.0
C.3.1 DIMENSIONS
[i]With the Boat floating in fresh waters :
LOA (with soft bumper included) 1150 mm to 1200 (+/ - 10mm)
LWL Up to a maximum of 1000 mm (+/- 3%)
Max Beam: 290 mm Min Beam: 165 mm
The official measuring for the boat is floated in fresh water, ready to sail, with one elastic around the bow and one elastic around the stern; the elastics are shifted to the point where they touch the water. At this point the boat is grounded in a template of 1030 mm and the distance between the elastics should be equal to or less than 1030 mm. If a boat is heavier than 4500 g, during the official measuring the boat will use a lighter bulb so that the boat weights 4500 g: if it falls within the waterline length 1030 mm, the boat is in good standing and in racing it will use its original bulb heavier.[/i]
The wording here is open to interpretation, but thankfully 1040 mm LWL did not make it:rolleyes:
C. 5.1 LIMITATIONS
The appendages are composed by one Fin (two, if the real ACC boat has two keels as NZL-20 for example)/Bulb assembly (two bulbs [with a total weight using two keels of 3000 g] if the real boat has two bulbs) and by one Rudder.
D.2.2 CONSTRUCTION
The construction is unrestricted except for the following:
(a) The Hull shall be a Monohull type
(b) Except for trunking for the Fin and Rudder, the hull shall not have:
(1) voids in the water plane and/or the underwater profile
(2) hollows in the plan view and/or the underwater profile that exceed 3 mm
(3) transverse hollows in the under surface of the Hull that exceed 3 mm when tested parallel to the water plane.
© the forward 10mm of the Hull shall be of elastomeric material
(d) the Hull shall have two marks at the water plane level, one in front and the other to the back. These marks are used for the LWL length measurement.
(e) The max beam must be always measured on the deck.
(f) The hull must have minimum 45 mm overhang at the bow and 65 mm at the stern measured using the elastics and template system (see point C.3.1)
(g) The bridge must be flat or curved with a maximum of 5 mm. Behind the mainmast is required a cockpit with a minimum depth of 20 mm. The line of contact between the bridge and the hull can have a round fillet of a diameter of 5 mm or it can be 45° sloped only if also present in the real boat.
(h) The width of the stern must be between 30% and 62% of the maximum beam and should not be higher than 120 mm and should not be lower than 70 mm.
A.1.1 AUTHORITY AND RESPONSIBILITY
Each Club using the AC120 Class is responsible for the assurance of this Class Rules observations. The Regional Clubs shall designate a responsible Member for this purpose. Each owner will be first of all responsible for this Class Rules observation. In case of errors of In case of errors of translation, the correct Class Rule is the Italian version.
I should point out here that these are Italian rules only and if anyone is considering class rules in their own countries I would strongly recommend that you should not follow the Italian rule word verbatim as they will lead to problems, I would recommend class should have max LWL of 1000 mm, naturally without meniscus.
Cheers Alan
