Hi, will try to explain how I did it and what problems I encountered.
@ Alan. I think you are absolutely right, you are supposed to bag it before the resin goes off. But I can’t wet out and arrange the fibers in the mould fast enough. Maybe I have to look for a better method of wetting out the fibers. Currently I am applying the resin with a painting brush. Have thought about pouring out the resin over the fibers (plastic lay-up method), and then distribute the resin with the brush in stead of applying it with the brush…
Back to the hull and how the lay-up went…
I had all the fibers cut, according to a template generated from the CAD model so I had about 10-15 mm extra width of the fibers. This turned out okay.
Mould was waxed and polished 4 times.
Temperature during the lay-up was a little less than 20 degrees properly 17-18 degrees. The resin was stored at 24 degrees over night, but I guess that the temperature in the mixed resin batches goes down pretty quick, especially when distributed over the area of the fibers. This could be a source of some of the problems.
The outer 80 g/m2 glass layer and the first of the two 160 g/m2 carbon layer were wetted out and applied using the plastic method. But it almost went totally wrong with the carbon layer, so wetted out the last layer in the mould. It seemed the draping and arranging of the fibers was easier this way, but it is very difficult to be sure if the fibers are wetted out properly.
All fibers are arranged at 0 & 90 degrees, so the draping was a bit of a challenge. But from my previous tests, I found that this direction of the fibers gave the part the best characteristics.
Both fibers, peel-ply, perforated film and breather was cut according to the same template, so they where all the same size.
I struggled a bit with the peel-ply… properly spend 10-50 min making it drape. The roll of peel-ply that I’ve got is not wide enough to arrange it at 45 degrees, which could properly speed up that part of the process. Arranging the perforated film was pretty easy. The breather was also a bit tricky, especially in the bow, which is very narrow, but it was possible to squeeze it all in there.
I put the whole mould and lay-up in the vac. bag and made sure there was plenty of bag material inside the mould, so it wouldn’t have to stretch. The vacuum connection was placed approx. 5 cm out side the back end of the mould. As mentioned earlier, it was properly about 3 hrs from first epoxy batch was mixed to the vac. was applied.
Vacuum applied was aprox 0.55bar. The whole lot was moved to a room with a steady 24 degrees C. Vacuum applied for about 4 hrs.
My hypothesis:
I think the lay-up went okay actually. Maybe a little slow, but maybe the low temperature gave me longer pot life, but also thicker resin.
For my tests I used maximum 0.3 bars vacuum, but as I thought the first layers of resin had already gelled up, I applied 0.55. I think this is the main reason for the problems. It can also be seen from the pictures that the back-end, close to the vacuum connection is missing a lot of resin. I weighed the breather after taking off the mould and it had gained a good 100g, which also point in the direction that too much resin was vacuumed out of the lay-up.
The other big problem is the edges. I cannot figure out if this is actually caused by the breather material and vacuum bag messing with the fibers, or it is caused by the fibers not being able to bend around the sharp edges of the mould. My solution to this problem would be to trim the wet fibers in the mould before applying the film and breather. I am also not sure if the film and breather should be trimmed to fit the fibers or if it should overlap the fibers. Also I have to be more careful when arranging the bag around the edges, but I am not sure how to do it right.
Is it necessary to use the glass layer. It would save me some time, if this layer could be left out. Pin holes can be fixed by the r-g.de pinhole filler, and I plan to paint all my boats, so I don’t care so much about white pinhole filler spots.
I’m thinking if it would be an idea to order another perforated film before making the next attempt. The other available film has twice the distance between the holes, meaning 1/4th the numbers of holes this should give more fiber compression and not so much resin evacuation.
Have to stop writing now, as my fingers are bleeding from typing… :lol:
Regards Anders
