I’m quite satisfied with the boat. Here’s a summary of lessons learned so far:
Design:
This is sort of 1 1/2 generation boat, using hulls made by Nigel Heron for the free sailing student boat described at:
http://www.rcsailing.net/forum1/showthread.php?t=3953
This boat was designed with a balanced hull for straight tracking under varying angles of heel. A looong discussion of hull balance can be found at:
http://www.rcsailing.net/forum1/showthread.php?t=3436
The advantage of hull balance in a R/C model, especially when sailed by a duffer like me, is that the boat won’t suddenly dive and veer when hit by a puff or a gust – which in my case always seems to happen when I’m looking away from the boat to see where the mark is
It involves a performance penalty because balanced hulls typically have somewhat narrower transoms than unbalanced ones, which inhibits planing/surfing ability on the runs. It should be noticed, however, that the really wide-transomed ocean racers (like the mini transats) were designed to plane on long reaching legs which don’t usually happen in our kind of racing. IACC boats are better things to study, being designed for windward/leeward racing, although as with all classes you have to be careful of distortions introduced by the rating rules.
The original hulls are 30 inches long, with overhangs. Conversion to an RG65 involves cutting off the fore and aft overhangs and pinching the bow in a bit. This is the same approach the great British designer Henry Tucker used in his famous “Duck” M boats. The blunt bow above the waterline means you have to be careful about diving on the run, for which see below.
Narrowing the bow upsets the theoretical balance a bit but doesn’t seem to have any practical effect, as she keeps her head up even when heeled rail down.
The other problem with a fixed LOA class is diving under the run. Balanced hulls are inherently better in this regard because the balancing process in design moves buoyancy forward of the longitudinal center of floatation, the point the hull rotates around when pitching. Another thing that helps is concentrating weight around the center of buoyancy to reduce the tendency to “hobby horse”. Hence the tandem servo arrangement and the batteries on either side of the keel box. All this seems to have worked just fine and she has shown no diving tendencies so far.
Construction
Construction is conventional, and the 1000 gram displacement/500 gram ballast targets were met easily, even with heavy servos and alkaline batteries. The big lesson was how handy 3M 200 MP adhesive transer tapes are:
http://www.tapecase.com/c.108.1.1/200mp-high-performance.aspx
These comprise 2 mil thick 3M 468 pressure-sensitive adhesive on single-sided tape. Lay a strip on a piece of wood like an inwale, rub to set, peel off the paper and viola! a self-stick inwale. Set in place, rub, wait overnight and there you go. No goop, glop, or building up weight from excess adhesive or epoxy. Also good for tacking bulkheads in place, followed after setting up with a fillet of epoxy for the final joint. Anybody interested in lightweight construction needs to know about this stuff.
Biggest failure in construction was the use of a carbon fiber helicopter blade for a fin, which turned out to be way too flexible, so that has to be fixed. The jib radial also needs to be redone.
