At some point one need to take the jump and I did today with the help of a friend of mine.
I am a sailor and my strat experience is more gluing and fixing then building so any comments & advices welcome.
The boat:
We bought the mould of this IOM design from a friend of mine so I don’t have the plans but I do have all the measurements to install everything as part of the build.
The moulds being elsewhere for now but having hull and deck #1 with me for what was supposed to be boat #1 they came way too heavy at 586g for the hull and just over 300g for the deck - completely unusable for a competitive boat so I decided to use them as a male plug.
I got the idea and inspiration from reading posts from claudio and others
So my friends installed a wood structure to further strengthen the hull and deck and then gave it to me to sand down and get it ready. A bit of filler a bit of patience and a lot of elbow grease and the hull and deck are ready.
Next phase we sticked packing tape as used before by claudio ensuring overlap but not too much see photos.
next phase was the strat.
After much debate we decided to go for first hull with 2 layers of 135g (4oz) twill fibreglass cloth. I think 3 layers would have been better but agreed to go with 2 for see the weight and strengths.
I had pre-cut the layers of fibreglass and each weighed c60g (incl. excess cloth to hang the side) and mixed 50g of epoxy (west) + 10g of hardener + 3g of pigment
layed the 1 layer on the hull and started by the middle to the side on the whole length of the boat.
First issue is that it was easy to spread the mix initially but then it started to become tacky within 20mins or so (shed temp was 20C with 55% humidity).
Second issue we didn’t elevate the hull enough from the base and it was difficult to have the cloth sticking to the hull at the deck level.
Initially spreading the resine with a 2" brush, tapping the brush in parts to “force” the resine in the cloth and then a resine role (from west system) to have a more uniform volume of epoxy throughout the area, then a special lamination brush to remove any air bubbles. Looked good
then applied the second layer of fibre approx 20 mins after the first one and this time I used a little less hardener with the hope to get more working time. Same process as first layer - same frustration around the deck line due to the hull not being high enough, used 53g of mix this time
then applied the 95g peelply to cover the whole hull.
now I’m praying it will be ok :shake::shake::shake:
No idea the weight the hull will come out at, nor whether it will be stiff enough !
One question I have is - I don’t expect the hull to be perfectly smooth so what is your recommendation to have a really smooth finish with no pinholes ? this is to be a boat to race so surface is important as much as the weight. Was thinking if the hull is light enough to spread a final coat of epoxy thinned with acetone but don’t know by how much.
if the hull to usable but too flexible I am planning on addind another layer of 135g across the area where the finbox/mast will be.
Any recommendation, comments, advices welcome at this stage as we are still pretty novices
Sorry about the pictures - I saved them on my google drive but I can’t see them now - not the first files I can’t see… will post the pics as soon as i sort out this technical issue
