Hi Guys,
Last few months Graupner had run out of stock of my preffered Regatta 5172 winch used for 800 cm2 sail area IACC 120 that runs above 10kg. Looked around and could not find anything else that runs directly off 7.4 V Lipo (2 cell) excepting the very expensive RMG 280 until some-one recommended Eurgle winches from Hong Kong (Chinese I know always skeptical too)
64.5 g model specs are good (12 kg @ 7.2 V) with good speed and at incrediable price of only 15 Euro each, so I ordered six and including shipping it worked out less than price of one new Regatta winch.
Using my trusty FM 40 Mhz TX threw one in the boat and connnected to direct to 7.4V Lipo (via Rx) and as reported has lot jitters but tested out ok on the bench, in the water and after 2 hours it was like it lost signal to Rx and winch did huge over-run and ripped the block out of the deck :mad: trhis is when my problems began
Cut long story short, the history of six winches goes:
#1: Over-running: Pulled block out of deck - Tx Analog FM 40 Mhz direct from 7.4V lipo - run time 2 hrs until trash can
#2: Jammed: Sheeting caught on post - Tx Analog FM 40 Mhz direct from 7.4V lipo - run time 1 day until trash can
#3: Over-running: no boat damage - Tx Analog FM 40 Mhz direct from 7.4V lipo - run time 2 hrs until trash can
From here on figured the FM TX was problem so switched over to 2.4 system, when switched it on first time jitters had gone, great digital TX was possibly the problem.
#4: Over-running: no boat damage - Tx Digital 22.4 GHz direct from 7.4V lipo - run time 2 hrs until trash can
#5: Jammed: no boat damage - Tx Digital 22.4 GHz direct from 7.4V lipo - run time 2 hrs until trash can
Ok now only one left :rolleyes: added BEC to kick it down to 6 Volt and programmed the TX fail safe to 50% sheet travel, turned off the TX while the RX was still on and sure enough the failsafe worked with winch moving to 50% sheet position, good to go me thinks ? This was a classic, right on 2 hrs sailing brought the boat on shore (only because I had to swim after the boat twice before) put boat on it’s stand and bingo off it went & just manged to switch it off before it self-destructed.
Any ideas on what could be the problem ? or am I just getting what I paid for …JUNK !
My problem is that Graupner still have no supply of their regatta winches anywhere in Europe, any other worth while winch recommmendations I can try ?
Cheers Alan
P.S Pic reminds of that kids song, there are 6 green Eurgles sitting on the wall, if one should accidently fall there will be 5 green Eurgles sitting on the wall …etc . shet happens uh !
so took the dive and pulled first one apart.
Just email them with details (Tx, Rx brand, Battery specs, what the issue(s) are) and get a RMA number.
