Thanks Matthias, apologies for the late response (just back from business trip) I’ve planned to be at attend all 3 regattas in Ravenna, will inform with separate PM.
No secrets on this build, have attached all weights etc. for you to view & comment on please. From my perspective can say the following:
Complete Hull – I feel comfortable with final weight at 872 grams, it is strong and a rigid platform.
Appendages – Definitely got all these numbers in the wrong places with complete keel fin and bulb minimum of 3,000 grams I would like to reallocate weight differently from what I have by taking more weight off the fin and transferring it to the bulb, here I’m working on building CNC fin and need to mould heavier bulb … that is in the pipe line now for the sister boat.
Rudder is well under budget weight, (-38 grams) but it “looks” too big optically, it has been made exactly to Claudio dimensions, I have made 3 others rudders with smaller surface areas and will test once I have the rig tuned with original rudder, it’s not a weight issue this a matter of decreasing drag.
RC Gear – Maybe only weight saving here will be Lipo’s and this is on shopping list for sister boat as well.
Total Rig – here I’m only 10 grams over budget weight and this is using an “Alloy mast”, Changing to CF mast together with lighter materials for the sails should have more significant weight savings and once again going on the 2nd sister boat.
With these further possible surplus weight savings it becomes a question of where to use the additional movable ballast to improve the balance the boat & I will only know that after the first hull hits the water this weekend and is finally tuned.
Hey love your cool video of team Alinghi and looking forward to getting together on the water with everyone at the Italian regattas …
Mike really glad to hear your nearing completion & look forward to seeing some photo’s when you are ready, to your question when will the sister boat be finished ? well actually I now have two other sister boats on the bench, reckon the 2nd will be finished a couple weeks after I have fine tuned this 1st boat, need to see what other changes from 1st boat need to be made before closing hull.
3rd boat is a full experimental platform for airfoil mast with soft sail and to play around with fixed wing sail and delta rig, plus goofing around with adjustable bulb angle and a rudder integrated into keel fin and few other ideas, like a bendy keel.
Cheers Alan
P.S Matthias now waiting on your balance point values
