[quote=yar;44062]Again, thanks for the continued help. robert, read the link you provided - the laminate of woods covered by carbon is logical but that can’t be the “modern” way, then it talks about an aluminum “spine” yet the newer ones seem to be just foam with carbon skin.
In fin construction, if I use foam, is there some sort of stiffener inside the fin (like an aluminum or carbon tube) that runs the length of it? The exterior carbon “shell” can’t provide enough stiffness by itself, can it?
yar
Yar, I have built the fin described ( ply,balsa, carbon and carbon) on page 19 of the us one meter guide. One vacuum bagged and a couple not, and they were good stiff fins,( no internal structure except the wood) the vacuum bagged was a tad lighter and much smoother.
It is a good method for a home builder that doesnt want to make a mold.
I think that the wood core(balsa ply balsa) is easier, because you dont need a mold, the core on its own has more rigidity than foam or obviously liquid epoxy/ micro ballons and cabosil.
I guess the molds are more suited to production work, where you want parts to be identical and perfect finish ( possibly straighter too). I know vacuum bagging ads strength because of the lower resin to fibre ratio and fibre spacing, but do molds under pressure do the same thing( add strength)?
I am guessing they would( if you used a solid core) because you are just using a press, weights vs air pressure.
I know that fins (glass, not even carbon) provided on some kit boats dont have any internal reinforcments, just epoxy/ micro ballons and cabosil.
A spar is always going to make it stronger/ stiffer, but is it the most effcient place to add glass/ carbon?
If you look at plans for fins or fins for sale it will often say what the deflection is with a given weight, so you could use this as a comparison when building your own to see if you need to add more reinforcement.
What I have said is just as much question as comment, feel free to correct me.
Can we hear more from nigelpheron ?
How about a thread with pictures and instructions on fin building with a mold? I know its asking alot , but alot of people would like to know!
