2-metre trimaran build
Hi Dick,
it will be a foam plug glassed over - I will take the shells off this plug then. Its different from my last prototypes which were glassed over foam cores.
I could take some of your snow:) - we have over 30 deg here and 20 kmh winds - I will try to go sailing on the weekend if winds continue to blow.
I’m working on the plugs for a modified version of Siri’s 2m class tri.
Here is the progress so far
I try to get the boat into the water before spring.
Roland
Many springs late, I finally managed to assemble the raw platform. Building the boat is a real space issue, had to send my wife on holiday before I could start the assembly.
You can see two MultiOne boats hanging from the wall in the background.
More to come soon…
Roland
Nice. Are cross arms metal, or fiberglass. Foam filled or hollow? Thanks
Hi Dick,
the beams are foam filled fiber glass for the first tests. I will build a set of beams in carbon fiber after the first sailing sessions to save some weight.
Currently I’m working on the sail templates - they are huge.
Roland
Thanks for response. I am thinking of trying a hollow version of cross arms. Most of mine have been solid. Thought about a vertical thin ply shape, then add strips on top and bottom to form an “I” Beam of sorts. Finally fill front and back with foam, shape and glass. Will probably become a bit heavy with all the foam, but was a thought. I may give a try on the Mini40/F48 currently being built.
Cheers, Dick
My 2m platform touched water for the first time yesterday to perform a float test. I added 5 kgs of ballast before taking the pictures.
Roland
The custom winch for the 2m project is up and running.
//youtu.be/1XEKochhf4M
Now the day to sail the beast is getting close.
Roland
Sails are ready -
In the second picture you can see a full MultiONE rig on top of the 2m rig to see size difference.
Next step is sheet installation, after that it is time to put the beast on the water.
Roland
What a beautiful looking boat! I have never played with a multi hull in r/c but it looks like a lot of fun. I would need something a lot smaller tho … something like what is hanging on the back wall.
Tom
Well hanging from the wall are 1metre and F48 class multis. They are great fun to sail. If you get stung by the virus you will automatically go for the larger ones at some time. The 2m build consumes much more time than the smaller ones, no standard fittings are available, all has to be build by yourself. My 2m took around 6 years to materialize, now the build is nearing the end and I hope to sail the boat mid of this month.
Roland
I know about wanting bigger … I am working on a rather large tug boat that will weigh in at 65lbs, and I am awaiting the arrival of the laser cut frames for a 78" version of the Rainbow.
Are there any plans available for either of the smaller multi’s?
Tom
There are some free plans available at RCSails. You will need to register before you can get them.
Roland
Thanks Roland … I will have a look at those. I think I should really finish some of the projects I have started. With snow still on the ground, (and more falling as I type) it is easy to think that something new would be more fun to sail.
Tom
My 2m Trimaran finally made her maiden voyage.
I rigged the boat up at the lake early in the morning and did her maiden in a very light breeze. Some minor issues to address, but all in all the boat is a dream to sail.
I will upload a short clip of the maiden voyage to YouTube soon and publish the link here.
Have a nice weekend
Roland
Here is the video clip:
//youtu.be/ddeA76uQyM0
Enjoy
Roland
Very Nice! She can really get up and go can’t she!
Job Very Well Done.
Tom
Nice job Roland. Has nice set to hulls, even when wind picked up a little. Any plans to market - or sell plans?
Hi Dick,
no plans to market the boat or sell plans - the shadows can be downloaded from this thread, I have modified the first three float shadows for more scoop. I do have molds if anybody wants moldings I can provide them on case to case basis, the parts should be picked up because shipping cost for this size hulls are easily more expensive than a ticket to Thailand.
Roland
thank you. I wish you well with this “monster”.
