I decide to use the boat as a plug so I will be able to built a couple and race them as much-race racers.
This is the first coat of gel-cot on top of the balsa skin.
I have done this in the sailing club in Heraclion. I am not going to do that again there.
The ventilation of the place was not enough and the whole building smells styrene.
I did it with a friend whose boat you can see in the last 2 photos.
It looks pretty nice I think what are your comets?
It is a rainy day today and I can work my job.
So the fairing just started.
The shape is not bad but I think I will have to have a new coat of gel-coat
because there are places tha balsa has been exposed
And the big one behind it is the newest development cut in foam in a scale 1/2.5
The design is cut every 5cm an then glue them together.
Thank you claudio,
this is a big encouragement for me to continue the boat.
Today I had a new layer of gel-coat.
I did it with different color of gel-coat so as to be able to know how dip goes the sanding.
As you can see I did it outdoors but…
Do not use yellow gel-coat outdoors or you are going to end up with lots of flying bugs stick on your hull.
It’s been a while since I have posted any photos.
In the meanwhile I have added 2 layers of gel-coat since I created the surface I wanted.
Now the plug is ready for the female mold. All I want is to have enough layers of molding wax and I am ready to get finished with it.
This is the first boat that I am going to built.
I am going to use 1 layer of 200gr carbon twill 2x2 and 300gr biaxial 12.5cm carbon tape for reinforcement.
I am wandering, almost 400 times the thread has been viewed since I posted the last photos and nobody had something to say?
You are right my friend and compared with a friends IOM is like 3 of them in beam (42cm to 17.8cm)
About the keel, this is going to have a stable one for the testing
but I am going to have a second one to apply all my ideas and scale modeling.
I tried to see the real maximum displacement and this is what I did:
I placed the hull in the shower and filed the hull with water.
Then I poured the water in a bucket and I saw the weight of it.
Here are the photos:
So this is the maximum displacement that the hull mast have.
Now I am planning to put in the hull some bulkheads to strengthen it and also the keel box.
I also wait for the keel and the rudders that I have order that are different size of helicopters main blades.
Just yesterday I received my blades.
So today I created the keel fin box and I placed the bulkheads and the keel fin box in place.
The fins are absolutely perfect in shape and strength.
When the epoxy is ready I am going to trim the diagonal bulkheads and finish everything for the deck.
Here are some photos of the project:
