Introduction
Last July, I had been playing around with a test hull featuring a very long bowsprit and a single sail, which was a jib with a large rake angle (see thread entitled “Slighty Unconventional”. The objective was to get enough lift from the jib to avoid nose-diving when running. There were several questions that needed to be answered. First, could it be balanced sufficiently to sail to windward without a lee helm, which it could, by moving the keel far forward. Secondly, would this scheme prevent nose-diving. It helped a little, but not enough to be worthwhile. It appeared that any further improvement would need a longer bowsprit, which would prevent balancing the rig. But recently someone has mentioned building a ketch. This made me realize that the bowsprit could be lengthened if a small mizzensail was added, hoisted on a second mast mounted on the transom. Therefore I did some testing to see how long a bowsprit is needed.
Test Set-up
The test set-up consists of 2 picnic benches, a pencil, a string, and a large fan. The picnic benches are facing each other, with a gap of about an inch between them. This allows dropping the keel of the test hull between the benches. The test hull is balanced on a pencil which spans the gap between the benches. The fan is placed on the benches and blows wind into the sails. The string is tied to the rudder to keep the hull from sliding forward from the wind pressure.
Test Results
The initial testing showed that the balance point moved forward about an inch when the fan was turned on. However, this was not a very useful measure, since this was outdoors, and there was always a slight wind blowing, which made it difficult to get an accurate calibration. So I moved the keel weight fore and aft, varying the position of the balance point, until I found a balance point where tthe wind made no difference, and the fan made no difference, the hull would just sit there. The end result was that the bowsprit needed to be lengthened significantly (started at 9", increased to 13").
Correlation to expected results
I had made some calculations, using a free body diagram as in Physics 101, which indicated that a bowsprit of 11" would be needed. So the results are at least in the general ballpark
Tested sail
The tested sail has a 45 deg luff angle, with a 17.5" leech and a 17.5" foot. It is mounted to a club which has a swivel attachment to the end of the bowsprit about 25% aft of the tack. The club is counterweighted so it will swing out easily.
Comments
This is not a very accurate procedure, for several reasons enumerated below, however it may be sufficient for the intended purpose.
The wind created by the fan is probably quite turbulent, but the flow across a stalled sail going downwind is also probably turbulent, so it may not matter too much.
The wind created by the fan is not uniform across the sail, which will cause some inaccuracy. An enclosed tunnel, with a screen at the input end and the fan at the output end, would be better, but would be quite large.
On a boat in the water, the wind flow off the bottom of the sail will be blocked by the water. This is approximated by the existence of the picnic benches under the boat.
