“Niel, I saw the whipstaff arrangement in your boat, and liked it. I don’t recall, though, what material you made the various bits from…nor did I see how you attached the tiller to the rudder post. Any advise for those of us who might like to make one?”
Thanks…Bill H
Bill and all, following are the specs and some pics of the whipstaff rudder linkage that I use on “Tanto”. This system worked better than I had expected. Steering is very smooth and I have not had any difficulty turning the boat in adverse conditions even though Tanto sports a rather large rudder.
The geometry of a steering system is important to understand, so a comparison of the ubiquitous push/pull linkage and a whipstaff one is the place to start. First, whipstaff steering involves a tiller arm extending from the rudder shaft that engages with a pin and slot arrangement to an arm extending from controlling mechanism. Whipstaff, or tiller steering, was the common linkage in vane sailing. When model yachting changed over to radio control the push pull linkage became the norm for two reasons; first, the availability of off the shelf parts from r/c aircraft, and second, the large distance on most model yacht classes from centrally mounted electronics and the rudder well aft.
The push/pull system converts rotary motion (at the servo) to linear motion (connecting rod) and then back to rotary motion (rudder arm). Because the neutral position of the rudder servo is at 90 degrees to the direction of travel of the connecting rod the rotary motion of the servo moves the rod in an arc, with the linear, fore or aft travel of the rod diminishing the further the servo moves from neutral. What this means for you and I is that with the push/pull linkage most of the steering leverage occurs with little movement of the rudder servo and as one calls for more steering at the transmitter less leverage becomes available because of the diminished rod movement at the end of the rudder servo’s arc. This is why so many sailors, particularly new ones, over steer.
Whipstaff steering is a rotary motion to rotary motion linkage. As such, the rudder input from the servo is output directly to rudder making the steering effect more even across the turning arc. Because the engaging pin from one arm (in Tanto’s case the servo) slides in a slot in the other there is linear motion, only this motion is across the hull at the intersection of the turning arcs of the two arms.
My version of whipstaff steering uses the following:
Servo Arm - 2-1/2" long balsa core/carbon sandwich arm w/ pin (5/8ths, 2-56 bolt w/ section of 11.5GA S/S hypo tubing as sleeve), 2-3/16ths from servo pivot to center of pin.
Rudder Arm - 1/16th Delrin, 5/16ths wide by 3-1/16th long, slot is 1" long by shy 1/8th wide, starting 1-5/8ths inches from rudder shaft, ending 2-58ths from rudder shaft, w/ 7/32nd diam. brass rod drilled for 3/32nd diam. rudder shaft and drilled crosswise and tapped for 4-40 set screw, silver soldered to a 1/64th thick brass plate w/ clearance holes for 2/56 bolts tapped into mounting holes in the Delrin arm. Delrin was used because it is a bearing material. It is important that there be very tight tolerance in the slot to pin interface. The pin must slide easily in the slot but not be a sloppy fit or the rudder might vibrate. Expect to replace the rudder arm when it gets warn.
The distance from the rudder shaft to the rudder servo pivot is just over 4 inches. At neutral the center to center distance from the pin on the servo arm and the rudder shaft is 1.800 inches or just under 1-13/16ths.
I find that the even steering of my whipstaff system superior to the other systems I’ve tried. It is ideally suited to the Footy because the distances between the r/c guts and the rudder shaft are so compressed. It was used in the vane sailing days because it was easy to set up and understand. Push/pull systems would have worked with a vane but were not used. I wonder why?
If any of you decide to try a whipstaff linkage I hope that this has been of help. I credit Angus with re-introducing me to this method. If one searches past posts there are several other photos and explanations of whipstaff systems.
Good steering - Niel
