The only thing that a USOM and a IOM have in common is the length, well that and being RC sailboats.
The main problem in converting a USOM into an IOM is the weight limit. A ready to sail IOM has to weight 4kg minimum (a bit more than 8 pounds), a ready to sail USOM between 5.5-6.5 pounds? By bringing the USOM up to weight you would make it sail way below the intended waterline, slowing the boat down.
It?s much easier converting an IOM into a heavy USOM.
