Spent my lunch hour in my local hardware store today and there on the stand was a glue I had missed on previous visits.
I have cribbed this from another web site so do not claim the following wording as my own.
However i have stuck two 1inch bits of plastic bottle together and will test it tomorrow with a weighted pull from my spring balance and let you know the results
*** What is it? ****
This product is made by Loctite, and it is in their Super Glue range, this is called Super Glue All Plastic. It has been specifically designed to bond all plastics, especially the harder type plastics, such as Polyethylene and Polypropylene, which I believe a lot of children’s toys are made from.
This glue can be used for bonding all types of household plastics, on the pack it lists ABS and Perspex (I’ve never tried this on Perspex, but I imagine it would cause clear Perspex to glaze over!
You can use it for many other materials, such as wood, leather, metal ceramics, paper etc.
Again I’ve really only use it mainly on the plastics, and it does a brilliant job, I’ve not yet had to re-glue any of the things I’ve been called on to repair, some of which are used most days.
*** What is it Like? ***
This glue, comes in a card based pack, the pack is blue and yellow, with the word Loctite across the top. It has a plastic blister covering the 2 glue components, the first tube contains the Primer-activator, the second the actual superglue. These tubes are clearly marked what they are, and indeed they are different shapes. The pack says they are 2g tubes.
The pack I have has a small advert on the top saying “Team McLaren Mercedes Official Supplier” so if it hold an F1 car together then it can’t be that bad!
*** How do you use it? ***
Easy is the answer.
- First off, get the pieces that you want to glue together,
- Make sure they are clean dry, and they fit together. It is important that you do not touch the areas to be bonded, as the grease from your fingers can affect the efficiency of the glue.
- Apply the primer to BOTH surfaces to be bonded, and leave until dry - I have found about 1 minute is adequate. The primer is like a small felt chisel tipper pen, just “paint” over the surfaces, you really can’t tell that there is anything on the surfaces, but trust me, there is!
- Once dry apply a very small amount of the glue to ONE surface only, then join the two pieces together, and hold until the glue has set - on the pack it says 30 seconds, but I have found it is better to hold it for about 1 minute.
- Leave the item for about an hour before use - I actually do my glueing before bed, so it then has over night to harder - I have glued things and used them after less than an hour, and it seems fine.
Note: when using these 2 application type glues, it is important that you always put the cap on each tube before removing the cap from the next tube, it prevents cross contamination and wasting the glue!
As you only use a tiny amount of primer and glue, this last for quite a long time, obviously depending on how many repairs you make!
As long as you correctly put the caps back on, this glue should last years - I have had mine over a year now, and it still allows for extremely strong repairs.
*** Where do you get it? ***
This glue can be bought from most DIY stores. I got mine from my local private shop, but I’ve seen it in all the big chains. Price wise, I have seen it range from £3.50 up to £5.50. I paid £4.99 for mine.
*** SAFETY WARNING ***
I make no apologies here, I will quote directly from the packet
“CYANOACRYLATE. Danger. Bonds skin and eyes in seconds. Keep out of reach of children. Irritating to eyes, respiratory system and skin. Do not breathe vapour. Avoid contact with skin and eyes. In case of contact with eyes, rinse immediately with plenty of water and seek medical advice”
Ok sounds very dramatic. Yes is does smell - not too badly, but you know when you are using it. For the majority of instances, you will probably only be gluing one or two items, so not really a problem. I always use this in my garage, which is well ventilated - I’ve not yet managed to get any on my fingers yet, so I can’t tell how quickly it bonds skin! (although superglue was originally developed for plastic surgery!)
If you are concerned about the safety aspects of this, you can get information from the websites listed below.
Also if anyone wants to use this at work, then there is a lot of Control of Substances Hazardous to Health (COSHH) information listed on the website.
