Gentlemen,
I have shrink-moulded a footy using lemonade bottles, but the length of available bottles meant that I have to make the hull in two sections.
So I am joining the sections together with a 1/2 inch (12mm ) overlap joint and am looking for the ideal joining material or method.
The material is PET, and I am informed that there are no solvents for this plastic (please tell me if there is).
So I will rely on adhesive joining
I have tried PU adhesive (Gorilla Grip) - it does not adhere well (I had slovent cleaned and abraded the surfaces with wet-and dry paper
My current thought is hot-melt adhesive - so I will need to apply a very thin layer to one surface, assemble the two bits on the former, and gently iron the two parts together without shrinking them more.
Has anyone got any better ideas for adhesive joining that makes a strong and flexible joint?
andrew
