Doug,
Yes, you and I have chatted about the limitiations of a canting rig before. Canting keels are preferred but the “established classes” do not allow that. I was pointing out that there are ways to get some of the advantages of a canting keel system while working within those rules by using a canting mast instead.
Indeed, the additional loss associated with wetted surface area of the wings on the keel downwind would take away some of the advnatage of the extra righting moment upwind. A comprimise I think can be found with high aspect ratio cambered wings. With a cambered wing you get more lift for a given surface area. So you could minimize the extra surface area while maintaining a lot of lateral resistance upwind. The key would be in setting the angle of attack right to also minimize the induced drag downwind.
While this would still be sub-optimal compared to a proper CBTF system, I would certainly be an advatage compared to fixed rig US1Ms, IMHO.
JohnB,
Have you looked into gyros? some of the aircraft Gyros have some really sophisticated damping and rate properties that may get you out of the hunting problem. Also, you could set a “bucket” of say 10 or 20 degrees in the middle of the range where it would try to control the keel. If you heel outside of this range, then it forces the keel all the way to one side or the other. This would mean that for upwind work, the gyro would be commanding full keel deflection to one side or the other depending on which tack you were on and the gyro would not deviate from that commanded keel deflection unless the boat returned to neutral heel.
Just some thoughts. I would be interested to see how it worked anyway…
Roy,
Yes, you are right that the balance equation is dramatically different when you are sailing with your rig upright versus at a heel. This needs to be accounted for in designing the boat.
boats normally want to head up more as they heel over. This is because the center of drive in the sails moves abeam (to leeward) of the center of drag resistance of the hull. This generates a moment that causes the boat to want to head up. This is why boats generate windward helm as they heel. In some boats, this can cause control problems in gusty winds as the boat will tend to snap to weather when blasted with a puff.
With a canting rig system, the equations get a little different. But if you have your rig fully canted (i.e. you are not adjusting the cant as you sail), then the response to a puff will be similar to a fixed rig boat. The difference is that the canting rig will remain more upright in the puff (because of the extra righting moment of the keel) and therefore need a more extreme puff to get to the “snap” weather helm point.
One of the problems as a designer of canting rig systems is that your mast canting system must support the rig (unstayed). Therefore, it needs to be pretty beefy and that usually menas that it need to be attached to a bulkhead. That limits the amount of adjustment you can make to the fore/aft position of the rig. (you cannot have 3 or 4 positions on the mast step). Therefore, care must be taken in selecting the position of that bulkhead so that you end up with a well balanced boat in all wind conditions.
For my prototype boat, I plan to build a set of blocks into each side of the boat with a set of threaded holes. My mast bulkhead will have a bracket that will allow me to screw the bulkhead into these blocks on either side. This will allow me to move the bulkhead fore and aft as I experiment with the correct position for the base of the mast to give me optimal balance.
If I design the system correctly, I may be able to also rake my rig fore and aft with forestay and backstay tension to fine tune my balance in the finished boat. The key is to place all critical attachment points (jib pivot, mast pivot, sheet fairleeds and backstay attachment point) along a single axis. That way the rig can cant from side to side about that axis without changing any of the tensions in the rig or the sheeting angles of the sails.
Bottom line is that I think the balance issues can be dealt with. You may just end up at a slightly different mast position to get to that optimal balance. I don’t see that the change in balance as the boat heels will be any worse than a standard boat, and may in fact be better.
