I have some lightweight coated nylon from a tent rain fly that I am going to recycle into some sails for my JIF65. Just wondering what direction the weave should be going relative to the luff.
Brian
Brian
At right angles to the LEECH.
Don`t worry about the Luff.
Thanks IanHB. Just showing my inexperience:) Lesson learned.
Brian
Usually, the warp (the long side of the material) is set parallel to the leach.
The warp threads (run lenghtways) are often heavier than the weft threads (run across). So to get the max strength to resist stretch, the warp is the better choice to line up with the leech.
bkopke
you should look at this…
http://www.rcsailing.net/forum1/showthread.php?t=3110&highlight=sailmaking
alot of people responded to this. and there was alot of information given
this will help
cougar:zbeer:
good luck
Thanks for the replies. I’ll let you know how they turn out…
Brian
Hey Cougar, my brother is a big Tigers fans as well. We grew up in Monroe, MI so go figure.
yes… the truly are tigers fan…
the few
the proud
the detroit tigers fan
hope your sails work out. post some pictures and keep us informed
true tigers fans. will never take you down. now there is a cubs fan on this forum. that may have other opinions…right dan?
got to love steve bartman. and the 1984 tigers:zbeer:
WHO? is this ?
:):p:rolleyes:
