Sail Numbers - if anyone needs them
FRONT READING NUMBERS:
You can use photo copier to enlarge or reduce.
Place under mylar or TriSpi and trace numbers
Fill in numbers with permanent marker of your color choice
If you are going to cut from vinyl and want to trace on the backing sheet of the vinyl, (instead of on front of vinyl itself) see “Mirror Reading Numbers” below
MIRROR READING NUMBERS:
Cut out the square shape of the number
Paste to back of vinyl (backer sheet)
Cutout the number.
Remove backer sheet and vinyl can be applied directly to surface of sail.
Use these if you want to trace numbers on the BACK of the vinyl material
I have a variety of fonts (letter shapes) and if there are any special requests, I will be happy to print/post here for others to use. No - sorry, I do not have production equipment to handle die-cuts. Sorry.
