I couldn’t find the 360, but the 380… Is that the right model? Also, which ‘cheap’ alternative may I consider? This is my first boat, and I don’t want to go top-notch with it (probably the boat itslef wont deserve them)…
Will, the Wheeler carries 2000 sq. inches of sail while the RG-65 only 2250 sq centimeters (some 349 sq. inches). Also the LOA of a RG-65 is 65 centimeters (25.59 inches)… One wheeler can carrie my RG-65 (and myself)!
i use hitec’s hs645 mg on my kyosho seadolphin.its sail area is close to the rg65 and it still works fine after 5 yrs of use and abuse in salt water sailing
ed
Geez! I am usually really good with english and metric units…
Sorry to mislead you…
Will
Will,
Don’t feel too bad, we’re not doing a Mars landing here.[:D][:D][:D] Imagine how those guys must have felt[:-banghead][:-banghead].
It would be a rule of thumb basically because sail area is only part of the equation. The shape of the sail is going to affect how much torque is required to handle it. A very high aspect ratio rig such as you would find on a M class would not have the same requirements as the same 800 sq in on a Soling M for instance.
It’s a small difference, but enough of one that could affect the decision of which winch to install. Also the geometry plays a part since different length booms mean different amount of sheeting required, ergo different winch choice.
Local knowledge is worth 10 strokes, so see what everyone else is using and you will be spot on. As to the RMG 380, I use it on a 4300 sq in J boat and it handles both sails correctly. That’s horsepower![:D]
CONCLUSSION:
1.- Standard servos will do the job
Hi Marino,
definitively NO!
A stardard servo ist not strong enough for a RG65. In my JIF.65 i first used such a servo with 3,5kg/6V and it could not hold the sails. Then i changed to a Graupner 5077 with 5,0kg/6V but it has also problems in gusts.
Now i have a servo with 7,5kg/6V which works fine in all conditions.
