Hi Tallastro, perfectly fine questions…as the old saying goes, the only stupid question is the one not asked!
To answer the questions that haven’t been yet:
Your item #2…Since the restriction is 305mm above the box, a boat with a shorter keel could have a longer mast. Of course that introduces the classic tradeoff between size of rig and righting moment generated by the length of the keel and bulb weight, so designers will have to figure out their optimal compromise. Although I hadn’t anticipated it, I suppose a boat that fits on a downward angle in the box could have a longer mast, also, but again the tradeoffs would come into play.
Your item #3…yes, you are correct that one of the two rigs is unrestricted.
Our thinking on this point was that we didn’t want to restrict innovation with regard to rigs, but we didn’t want the number of rigs to get out of hand, potentially forcing people to have multiple rigs to be competitive. By limiting the number of rigs to 2, and severely limiting the size of the storm rig, we think that designers will have to be reasonable about rig size decisions. If they go too big, and the boat is overpowered during the regatta, their only choice will be the small storm rig.
I’d also like to point out, as Brett has done previously, that the box rule is the first Footy rule officially recognized by any organization. The rules Niel refers to were posted by Brett a few years ago as a suggestion for creating international consistency for Footys, but they were never sanctioned by any organization.
When Brett (New Zealand) was approached by the MYA (England) to collaborate on a rule for their sanctioning, he suggested that I (USA) be included in the discussion. The result of the collaboration, which included feedback from a number of interested people, is the box rule that has now been sanctioned by the Footy Class Owners Association (established by the collaboration) the MYA, and now the AMYA. As part of the process of developing the rule, we published it on this forum, requesting feedback. Since there was minimal discussion, the rule was adopted.
Anyone interested, I suppose, can trace back the threads here and follow the discussion that occured, although a lot of discussion took place off the forum, as well. Looking back at Brett’s original suggestions, I think it may be worth noting that:
- length is no longer restricted to 12 inches, depending on beam decisions and other design tradeoffs.
- beam is now restricted, where Brett’s original concept had no restriction.
- bowsprit length is no longer restricted.
- although only 2 rigs (rather than 3) are allowed, the primary rig is no longer restricted.
- keel depth, though restricted, can be greater than the original 8 inches, depending on hull draft.
- standard servos are no longer required, allowing the use of mini/micro servos…or 1/4 scale, if you prefer.
All in all, my view is that the box rule allows greater freedom, not more restriction, than the original “rules”…but that’s only an opinion.
Bill H
