Hi Ian, One advantage at being on the tail end of fleet is that it can only get better from there :lol: …and your right, it is all in the fine tuning.
Currently I have upper and lower shrouds with one straight spreader just below hound position @ 60% mast height (no jumper strut at top section of the mast) I thought at the time I can use the shrouds and fore & back stay tension to control mast shape. Top shroud base is abreast the mast and lower shroud aft of the mast, but feel this is not right.
Without a mast ram I now think the lower shroud should be more at 40-45% of mast height to better help mast shape control.
On my largest sail plan (78dm2) I have mast height from the deck of 1.7 meters, and mast shape is clearly critical on such a high mast, hence my search for mast shape control was first on my list, next size down sail plan is 74 dm2 with 1.6 meter mast height, these are my first sails and I know can change sail plan to have shorter mast height, and albeit a shorter mast would help mast shape control I’m more interested is what the effect of a lower sail plan C.E would be like for better heeling stability.
The wind maybe free, but sails aren’t so I’ll come back to this later on when I have better understanding on what I have to work with for now.
Reality check on mast bend: The backstay is tensioned so that the mast bend matches the mainsail luff curve. Fore and aft mast bend changes the shape of the mainsail in two ways. 1) the mast either pushes fullness into the body of the mainsail when it straightens, or pulls fullness out of the mainsail when it bends more 2) the head of the mainsail either twists off as the mast bends more, or twists off less as the mast is straightened.
The mast ram is then necessary on a high mast for controlling lower section of the main, I’ve come across no negatives so far? I’m more convinced now why a mast ram is the way to go ! btw could not find anything on deck mounted ram you touched on, if anyone has any details, would be really appreciate to look at this arrangement.
I sometimes think rigs on 120’s are designed to represent the real boats rigs rather than more suitable for best performance as a model. In particular the headboard does not hold the sail well and the main twists reducing power significantly maybe this brings us to your next point about of top mast control, using jumper struts.
As said earlier, I have no jumpers, and only because no-one else has (sheep syndrome … I know) are you saying the problem with a fractional rig where the forestay pull at the hounds creates a curve in the top of the mast with the pull from the backstay via head crane ?
Further, often thought that a long head cranes create too much leverage (read mid mast bend) anyway, I remember looking closely at what I think are the two best sailing/rig tuning in Italy (Luca RSA 09 last years Cup winner & Gabriel USA 71 this years Cup winner) on what was different on their boats compared to others … they both had jumpers, whereas others did not…never quite registered then, but now it is beginning to make some sense.
Gabriel had traditional jumper strut each side of the mast using turnbuckles for tension adjustment, it looked mast top heavy and Luca has single jumper strut which is mounted on “front of the mast” (facing forward) with one threaded adjustment screw through the strut for adjustment, looked smart and much lighter with minimum windage…thinking about it, both were always top 3 fleet racing finishers, so that discounts the argument about jumper weight and windage for me …it’s baloney and I’m now becoming a believer too.
On jumper adjustment I’m I right in thinking:
Jumpers too tight - mainsail too full in heavy air and can’t be depowered with luff and foot tension ?
Jumpers too loose - mainsail overly flat most of the time and you may get an “overbend wrinkle” mainsail crease that usually runs from the clew, diagonally up and toward the luff near the middle of the mast, especially when sailing up-wind and sheeted-in tight ?
Btw: don’t know if you noted in the drawing posted, but I’m also changing to a telescopic Fairlead post, to keep fairlead sheeting point as close as possible to the main boom. I found when the gap was too large (mast forward tilt in heavy wind) I could not sail tight-hauled due to the widening gap between post and boom.
Next you mentioned mast material oh la la … until now I have only been using aluminium groovy mast (foil shape) and I was thinking this was the reason for no stability to help control mast shape, I think I was wrong, without a mast ram, would have the same problem no matter what mast material we’re using, albeit the stiffer carbon mast would better than aluminium (without a mast ram)
I have purchased a carbon groovy (airfoil shape) when I was in Italy and also a round carbon mast to try all possibilities, just out of interest.
Ian we covered a lot here, thank you and really interested in what good advise other members have to say on this interesting topic also
Next question, what is the best position to have your shroud base (chain plate) in front, beside or behind the mast and their relation to spreaders? (Straight or V shaped) particularly for supporting fore stay tension.?
Cheers Alan
P.S thanks for extra reading from ec12 site and middle earth is a good place to be …weather forecast here saying first snow on mountains here this weekend :indiffere
