RG65 Mast Size
Hi
I am building my first RG65 to a Ch Detriche design called “Flipper” Its in his book “Thirty Small Sailing Boats For Great Fun” I am going to use a stayless rig with a C/F mast but am not sure what size tube to use on the plan it says 6/8mm. I do not have any other boats in the area to compair. What size are currently being used around the world?
I normaly Build and Sail IOM’s & the RG65 looks very small but should be a fun sail.
Regards
JohnK
Carbon Fiber with a dia from 6mm at 1mm walls or 7mm at 0.5mm walls
kind regards from germany
Sven
Hi Sven
Thanks very much for your help. 6mm x 1mm is readly available I will try that.
Regards
JohnK
That’s what I used for the swing rig on mine.
