a6m5a has reported a post.
Reason:
The message posted by Claudio is absolutely FALSE and offensive as demonstrated by my reply. IT is ridiculos to modify a shape of an object with a graphic software just to overlap two different objects. Every one can demonstrate the similarity of two objects modifying the shapes.
Post: AC100 eXtreme
Forum: America’s Cup Boats
Assigned Moderators: Dick Lemke, Earl Boebert, K1W120
Posted by: claudio
Original Content:
I think you have a problem !!
I just pickup a corner of your drawing AC100 Extreme :
summing up all the surface values indicated on the COA, I get 2606cm3 and not 2692cm3 as marked on the drawing
Further according to my calculations and assuming a LWL of 850mm, the prismatic coeficient is 2606cm3/4588cm3 = 0.568 and not 0.58 as written. and this may be a problem for medium/hight winds
The situation get worst once you calculate the loss of volume with the use of a LWL of 835mm that I extimate to be about 152cm3, derived from my calculation of the water plan surface that do not appears in the drawing - strange !!
The hull volume available for LWL of 835mm will 2606cm3 - 152cm3 = 2454cm3
If then you take this last option and you add 2454g + 342g of the appendix = 2796g and you substract the bulb of 1850g, at the end remains 946g for the total construction !
Is all that correct ?
