The guy wires between the bows and the carbon tube that sticks forward to support the jib tack look kinda worthless. You are not getting much downward pull out of them and if your carbon tube is strong enough to react the upward loading of the jib stay, then it should be strong enough for the lateral loads as well.
I would run the sidestays about 70% up the mast and about 50% out on each cross arm rther thant all the way to the top of the mast and all the way out to the hulls.
I’m not sure you need the dolphin strake under the main cross tube. Any carbon tube I have seen for this size application is going to be plenty strong without needing that support. If you move your shrouds inboard (as I describe in Item #2) that will help reduce the bending load on the crossbeam as well.
I assume you have sized your “pod” with some sort of RC gear in mind? It looks a little wide to me (especially if this is to be a 2 channel boat).
I have a spreadsheet for calculating the Ackerman angles for your rudder system. Let me know if you would like a copy.
I like the nice low main boom and jib foot. you may want to consider a compression vang for the main boom.
1, Spotted that already, wondered who would notice it first! The prodder will have to go up a bit.
2, There is no backstay so the sweep in the shouds is there to stop the lot going over the front, if anything they need to go further aft, you wont be needing to sheet out far enough to hit them. As the carbon tube mast aint gonna bend much and its a masthead rig it shouldent be much of a problem. If it is some intermediates could be put in.
3, No the dolphin striker would most likely used with ali beams, if you were building a low cost version with an iom rig (Although the more I think of it I will probally design a higher volume pair of hulls for an iom rig, as with that its going to be alot heavier) with carbon tube beams the compression shouldn’t be a problem.
4,Yes it is wide, I designed it to look pretty more than anything else! Most pods look like tupperwear boxes, so i was trying to avoid that!
5, Yes Please, will save some sketching and messing about!
6, The main boom might have a gnav (compression vang) or I might go with a track on the pod, if I figure out the best way to do it. I think with the jib it might be possible to make a cool little cuved track out of a curved carbon rod instead of the usual boom which raises the jib foot too high for my liking.
The displacement should be under 1.5kg, 1.2 being about perfect. The transoms will be a little low in the water when the boat is not moveing but it wont take much breeze to make the bows go down a little to compensate. Having the boat trimmed this way should also help tacking. The rudders will have T foils, just I havent drawn them in yet, the daggerboards and rudders on there are just for show, I havent done much work on them yet.
Dick, If you think you can get foam hulls light enough then I’ll post some…I cant see myself building one of these so if anyone wants to have a go they are more than welcome.
Luff 'em & leave 'em.
