Does any know if art tech receivers work with the same frequency, im asking because i have just purchased another one so i can run both boats from the the same transmitter, i have both bound correctly and working as they should, but, if im using boat one with saved model one i have noticed i can also run model two from saved model one…
Trucker - that is completely normal behavior.
“models” in the Tx are just a way to save setting/programming on the Tx side. There is no way the Rx can tell if the signal is meant for it or not once you have “bound” it to the Tx…
cheers buddy, its not some thing i have noticed with my other rc hobby, possibly my regime of of turning model off then transmitter hasnt made it so obvious…thanks
