Hi guys,
Would I like to know which the proportion of the length of the keel/rudder it is in relation to the ship RC X real ship?
thanks,
Hi guys,
thanks,
Hi Jean,
There is no easy answer to this question, but you might try reading this article on Lester Gilbert’s site:
Are you trying to build something to scale?
As muzza said, there is no easy answer. Generally speaking a sailing model will have more draft than its full size counterpart in order to obtain sufficient righting moment.
Remember if it is a 1/10th scale model it has 1/10th th length, 1/100th the sail area and 1/1000th the displacement. This means the SA/displ ratio is out by a factor of 10!
Hope this helps
Troy
