Took off the string and rubber bands and the wooden tube I made last night was just right.
Planed off the ridges and made it 8-sided.
Then I plugged the heel and the head to make them solid for about 6" at the bottom, and 8" at the top. A 1/2" square tenon was cut in the heel for the mast step.
The head is the same as the fore mast head except for a slightly increased rake angle. The head tenon was cut and the fit of the cap checked. The doubling was squared and the taper for the hounds cut in.
Then I rounded the mast between the base that stays 8 sided up to about 2" above the deck; to the trestle-trees; and attached the hounds just like the fore mast - glued and pinned with two 1/16" brass rods.
I assembled the cross-trees and trestle-trees, glued and pinned; checked for fit
Finally, the bottom of the mast was painted cream and the head flat black.
I found a nice old piece of pine with a good straight grain and decided to make the bowsprit from it.
The bowsprit is pretty straight forward. It’s square from the heel to just outside the bulwark, 8-sided to the end of the knee, and round out to the end. It’s 3/4" square but the bottom tapers up to 1/2" so it sits level with the deck, though not on it. The whole thing is 18-3/4" long.
I cut a hole in the bow for the sprit, worked it to size with files.
The bowsprit was made 8-sided from just outside the hull to the tip.
Then from just past the end of the head-knee to the tip, it was made round.
Cut the tenon in the end
Installed the shear-pin through the forward bitts - just like the real one had.
Put a coat of paint on everything and made a cap.
Finished up the pump hardware
Then I tried to figure out what the bees should look like. Couldn’t find anything in the plans or the books, but I knew I had a photo of the bowsprit from aloft somewhere, so I went digging. I actually found the negatives on 110 film, so I scanned them and put them up on a page HERE Unfortunately, the pictures didn’t solve my problem.
