I put some framing in the counter, which will get decked over. A block of oak was installed her to strengthen the rudder pivot point here.
While that set up I roofed cabin box-top and installed some internal structure in it. Some of the wood from the original Pride’s mast was milled into little logs from which I made the skylight, hatch, and trim around the roof. This was given a little oak stain to better match the original’s color. The binnacle box and the hatch doors have to be made yet. I haven’t found any pictures that show the cabin hatch, and I can’t recall how they looked (I didn’t live in this part of the boat)
The real boat had a big keystone shaped hole through the counter for the rudder head to pass through and turn in. I thought about this a while and opted not to do that. Instead I drilled a slightly over sized hole thought the counter for the 3/16" i.d. brass rudder tube. It was set in the hole with J.B.Weld and a 3/16" rod blocked and taped at the heel of the stern post to keep things lined up. This is more precise, stronger, easier, and more waterproof than making the big hole through the counter. J.B.Weld gets thinner before it sets up and will run out of holes, so a bit of tape was placed on the bottom of the counter and the tube pushed through it. The J.B.Weld fills around the tube held in by the tape. When it was set-up, the tape was removed and the tube trimmed almost flush with the counter underneath, and on top. The counter was decked over and the big keystone hole left open to give the impression of how the boat looked.
The rudder cut from 1/4" Plexiglas. I drilled the 3/16" brass rod that would be the rudder shaft for the 1/16" brass drift pins that will tie it to the rudder. Using these holes as guides, I drilled the rudder to match. The drifts were cut and everything dry fitted. The drift pins were soldered to the shaft, filed and sanded smooth. I squirted CA adhesive into each hole and quickly set the rudder post in and then everything went wrong. The CA set up so fast I never got the drift pins all the way in. In trying to tap it in, the solder joints broke and I wound up peening the pins over on the shaft and a piece of the rudder head broke off.
Except for a slight gap between the rudder and the shaft, everything seemed tight. I even tried pulling a drift pin with the idea of saving the shaft and starting over, but I couldn’t get it out, so I decided to go ahead and give using this rudder a shot. I touched some heat to the pins to maybe reset the solder and filled the gap with J.B.Weld. The broken head was replaced. I made Constellation’s rudder the same way and didn’t have this problem, so I wasn’t expecting it this time. I’ll know better on Macedonian’s rudder. I’ll flatten the drift pins on one side, set them half way then squirt in the CA.
The heel of the rudder is held to the boat by a gudgeon plate. This plate is made in two parts; a mounting plate that attaches to the keel with wood screws and epoxy, and has holes threaded for two machine screws that hold the second part; the gudgeon plate, that holds the heel of the rudder to the keel. It’s made to be easily removed in case the rudder needs to be removed for some reason.
I made the plate from the same heavy copper sheet Constellation’s gudgeon plate was made from. Because of the rake of the stern post, it had to be bent into a ‘Z’ shape. I morticed the bottom of the keel so the mounting plate would sit flush with the bottom of the keel, and predrilled the plates. That all done, I had to get the brass screws to put it together.
I found some #2 brass wood screws and some #4 brass machine screws without having to buy any more, so I drilled and tapped the holes in the mounting plate, and drilled and counter-sank the holes for the wood screws. The holes in the gudgeon plate were opened to the right sizes, and the mounting plate was screwed and epoxied to the keel. When every thing was set-up - the model had a functioning rudder.
A pair of beams were installed in the hull for the battery to lay on. The battery is held in place by peel-n-stick tabs of Velcro.
I actually have very few pictures from my time on Pride. My camera was broken before we went to Yorktown, and some photos I know I had I haven’t been able to find. There’s not a lot on the Internet either - searches for Pride of Baltimore turn up much much more on the Pride II than the first boat. Greg Pease’s book, Sailing With Pride has actually been a big help. It’s full of photos many of which reveal details I need and couldn’t find elsewhere. It’s been especially helpful where the boat’s construction deviated from the plans, such as the shape of her transom. That I found the book for $5 wasn’t bad either.
