Brought forward from a previous post but different thread:
[COLOR=blue]Something I didn’t know. I just read on Sails Etc that if epoxy cures at say 20C then later it can soften (warp) at any temp above that. If it cures at 40C it doesn’t soften until the temp is above 40C. What this meant to me is that if you build a fin(or hull) in the winter when your shop is cool it will be more vulnerable to summer heat. I’m thinking we should all be making an oven so that all our epoxy parts will be cured at 35 or 40C. That way we don’t have to worry about the sun so much. Apparently you can heat treat it after to raise the softening temp[/COLOR]
[FONT=Arial]
The response received:
Hi Dick,
Thank you for submitting this questions and posting this answer in your RC Sailing forum. The physical characteristics that you are referring to is a an epoxy’s Glass Transition Temperature (Tg). The Tg is the temperature in which cured (vitrified) epoxy becomes molecularly active after the initial curing. When epoxy is formulated, the specific chemical compounds that used will determine the epoxy’s overall attributes. This includes the compression yield, hardness, tensile strength, tensile elongation, flexural modulus, flexural strength, tensile modulus, annular shear, izod impact and the Glass Transition Temperature.
Certain epoxy formulations are room temperature cure, where the epoxy formula reaches its maximum physical characteristics at room temperature. If these room temperature cured epoxies are heated significantly beyond their Tg, they can start to soften as a result. In the case of 105 / 205 system, the Ultimate Tg is 142 degrees Fahrenheit. Now this is not to say that at 143 deg F that 105/205 turns to soup. This attribute is determined by a specific test procedure on an instrument called a Differential Scanning Calorimeter or DSC. The machine can measure subtle changes in the test sample as a result of elevated heat. At 200 deg F a sample of 105/205 will become malleable, but when cooled, becomes just as a hard as it used to be.
There are epoxy formulation that are used in more technical applications that benefit from a Post Cure. A post cure is additional heat that is applied to an epoxy part to help it reach its full physical characteristics. These formulations are such that there is a significant amount of energy that is in the epoxy in the form of chemical compounds that create higher physical properties. However, there is a problem for these more technical epoxy systems to reach these higher physical properties. When the epoxy is reacted, and the material starts to plasticize (get hard), the ability for the molecules of resin and hardener to find each other and crosslink becomes increasingly difficult. In this case there are partial cross-links formed and in some cases un reacted material. These initial room temperature cures of these epoxy systems give way to a material that is quite brittle, hence why we call this the ‘B’ Stage. These epoxy systems require additional heat beyond the initial Tg to allow the material to become chemically active again and aid the continuation of the reaction and cross-linking.
Now achieving these high physical properties is a little tricky, if you heat the part to fast and too high of temperature, one can actually stunt the development of the physical properties. This is known as over shooting the Tg. Let me provide and example, if a technical epoxy system room temperature cures to a ‘B’ Stage and while at that ‘B’ Stage, the epoxy has an initial Tg of 135 deg F, If that epoxy system is then placed into a 200 F oven the material may heat up too quickly beyond its ultimate Tg and there will be additional reactions and cross linking but because of the rapid heating molecules that could have cross linked become entrapped and can not cross link thus creating a condition where the ultimate physical properties can never be reached. Instead one should ‘chase’ the Tg, where the part is slowly ramped up to temperature. During this ramp time, as the part approaches and exceeds the initial Tg, additional reaction and cross linking is occurring and the physical properties are being increasingly developed, including the Tg. So at as the part reaches and exceeds 135 F, the Tg is no longer 135 F, it may be 145 F, but as the part reaches 145 F, now the material has had a chance to additionally cross link and the Tg may increase to 150 F and so on until the material reaches it highest possible physical characteristics.
There is however a ceiling on how high these properties can be developed, this is based on the chemicals used and the formulation. [COLOR=darkorange]In the case of room temperature cured epoxies, there is no significant advantage to laying up a part at 20 deg C and then post curing at 40 deg C. The physical characteristics will be achieved regardless of that additional heat. Now heating a part up to a slightly elevated temperature with room temperature cured systems, will help the epoxy system reach their ultimate properties more quickly.
I hope this helps to answer your questions, please feel free to contact me directly for additional answers to your questions.
Best Regards,
John M Thomas
Technical Advisor
WEST SYSTEM Epoxy
My sincere thanks to John Thomas and the Gougeon Brothers, for the technical response to my original question. I took the liberty of bolding one portion of the response, and highlighting another in ORANGE that I felt directly addresses the question/concern. Also, This is based on the WEST SYSTEM products specifically, but may vary depending on the actual epoxy formulation of the product/brand you may be using.
Glad I could help and again - a tip of the hat to the guys at Gougeon Brothers.
Dick[/FONT][/COLOR]
