Don - you are correct, in that there could be flair or not. If you look at next illustration, you will see a top view showing multiple waterlines. Some designers will include a split top view. In big boats they generally do half as a deck view and half as an interior view showing bunks, lockers, etc. In that case, you are correct in not knowing exactly what the designer had planned. This is where additional photos, or pond-side viewing would kick in and allow more accurate (to the eye) shapes to be built. In my “supposition” I thik I stated I assumed a flat side to waterline, and a circular section underwater for basis of keeping it brief. Again, I apologize if I lead you to believe you could “clone” a boat with only two views and no buttocks or water lines available. My apologies. I was trying to explain that you could get close to a design - but that is why we pay the designers money for thier plans, rather than posting a lot of detail dimensions which is why the guy is good (or maybe not) since he probably has gone through several iterations before getting it right (fast).
I just think that the original intent of the post was great - depending what the designer agreed to allow to be published. After all - I suppose we could wait for someone to post the calculations for a CAM program to feed into a mill to create the plug. Where does it end? At the point where the owner of the design agrees on how much he wants published, would be my guess.
Back to computer aided machining, I suppose you could take a known hull, turn it upside down and zero out all dimensions. Then using X-Y-Z axis, move a dial indicator all over until it just touches the hull, and record thos numbers. Will give you all the necessary points as well - but why go through the trouble to save a few bucks. If the boat design intrigues you (not you personally here - all of us collectively) then pay to buy it, or design your own determining your own template dimensions.
