New Sailboat From Graupner, Trueblue
Graupner recently has introduced a new sailboat to it’s line-up, the “Trueblue”. Weight is 8 lbs 4 oz. ready to run, length is 1000 mm, height is 5-1/2 feet, width is 8-1/2 in. This is a one meter boat that uses GRP (glass reinforced plastic) for the deck and hull. This boat replaces the “Saphir” and requires much less building. Since the hull is colored in a beautiful shade of blue no painting is require. The interior of the boat is roomy however all of the electronics are packaged into a small space which is accessed through a hatch in the deck. Once the receiver, battery and servos are installed the deck is glued to the hull and this seals the deck to hull for water tightness. There are three brass tubes inside the hull which you glue in place using either the provided Epoxy or, as I chose to do I used PFM, or Goop to seal the rudder tube, mast tube and keel tube to the boat. Once these are lined up and glued in place you then apply Epoxy, or Goop to the deck openings where the brass tubes enter and attach it to the hull. The hull is sealed to the deck using a special solvent that Graupner provides that melts the plastic and forms a permanent bond or weld. “Trueblue” uses two high torque servos ganged together to provide enough power to work the mainsail and jib. All of the necessary hardware is provided in the kit as well as glue. The instruction manual is in French, German and English with illustrated drawings. The only confusion I had was in the rigging of the mast. I wish they had more pictures and close-up detail pictures of exactly how it’s done. They do call out all of the measurements which helps since rigging will only work in a certain way.
All in all I really enjoyed building “Trueblue”. You will need to purchase two full size hi-torque servos, I used Hitec HS-645MG for the sail wench and one Hitec HS-322HD for the rudder. The battery box is sized for four AA Alkaline batteries however you might be able to squeeze in a 5th cell somehow to wake up the servos. Of course you will need a 2 channel radio receiver and transmitter. Controls are sail wench and rudder control. Graupner recommends you remove the stick centering spring so that the sail setting will stay where you put it. I used a Ranger 2 channel system and one of the servos that came with the radio system for the rudder. I have not yet sailed the boat due to weather here. As soon as I do I’ll post a video, I expect “Trueblue” to sail extremely well since she’s such a clean ship. Graupner “Trueblue” will be available soon at www.hobby-lobby.com. Expect to spend 12-16 hours building the boat. Suggested retail will be around $289.00. This boat is for beginner to intermediate sailors.
Gary Morris
A member of my club has just got one. From what I’ve seen, it’s a nice looking boat. We have our first club league this weekend, so I’ll get to see how it performs.
The weather here in Nashville has not been favorable for sailing just yet. I want to be able to wade in in case there is a problem but the water temperature is still in the low 40’s here. Maybe this weekend I’ll get a chance to sail her, if so I’ll shoot some video. Please let me know how your club member’s boat sails.
Happy Sailing!
Gary Morris
Here is a link for the maiden voyage video, http://www.rcgroups.com/forums/showatt.php?attachmentid=1743007
Gary Morris
Why link to a different forum?
Garry, looking good so far.:cool:
Here are a couple of tuning comments…please take as positive.
Too much sag in jibstay. . Tighten backstay.
Too much twist in main leech. . .tighten boom vang.
Main is out wider than jib at closehauled. . .bring in main closer to centerline,and ease out jib halfway to shroud.
Jib luff looks wrinkled and soft. Tighten jib halyard.
There! That should do it!:zbeer:
Thank you very much for your valuable input, I appreciate it greatly since we have no RC sailors that are knowledgeable in my area. I have made your suggested changes and just waiting for a break in the weather to give her a second voyage.
The reason I used a link to another forum was because the file length of the video was large and I didn’t want to try and post a video here because of the file size.
Gary Morris
