Still more …
STRATUS
A1998 Ten Rater from Graham Bantock, designed to use the foils common to the Marblehead Cumulus, and compatible rigs. Single sheet plan showing all sections, foils and hull data, with isometric drawings. Designed by Graham Bantock.
$ 14.50
Order no.: MAR2640
SNAPDRAGON
A Mini40 class racing trimaran design, 1.2m length and beam, intended for home building in balsa planking, or cut from blue foam and covered in glass cloth. Plan shows all frames for both central hull and floats, rigs and daggerboards and rudder profiles. Designed by Mike Howell.
$ 10.00
Order no.: MAR2394
FREIGHT TRAIN
A 1994 design by Andy MacCulloch to the Mini40 Class rules. Plans on two sheets gives plenty of construction details for this very competitive design.
$ 14.50
Order no.: MAR2432
MIDNIGHT OIL
An International 2M class trimaran multihull. Single sheet plan with design lines only, for experienced or adventurous builders only. Length 2000mm, beam 2000mm, and mast height 2600mm. Designed by Andy MacCulloch.
$ 14.50
Order no.: MAR2607
TWISTER MK2
A MYA Radio 36R class design by Adrian Brewer, updated by John Henningham. Based on a ply chine panel hull, suitable for anyone with a little modelling experience. Fully size hull sections, fin and rudder with some construction information. Designed by Brewer/Henningham.
$ 10.00
Order no.: MAR2355
FIJI MAGIC
A variation of John Spencer’s Why Not hull to produce an original una-sail schooner rigged model for fun sailing. Plans drawn by Henry Farley on two fully detailed sheets with rig and sail data. Designed by John Spencer.
$ 14.50
Order no.: MAR2425
6T6
A “six metre” design essentially for ‘fun’ sailors. Double chine construction in ply panels. Simple to build and cheap too! Plan shows all frames at full size and side view at half scale. 60" loa, 25lb disp. 1063 sq in. sail area. Designed by Adrian Brewer.
$ 14.50
Order no.: MAR2322
ORCA II
A series of Radio A Class designs, as you can choose the optimum waterline length and sail area for your local conditions. W/L can be varied between 46in. and 54in., and full details of all dimensions are given on the plan for all variants between these parameters. Features include the Delta bulb keel ballast. Designed by Bob Sterne.
$ 14.50
Order no.: MAR2335
FORCE 6
Six Metre Class yacht of round bilge section, intended for planking in timber, and for serious racing. The plan shows full size frames, fin and lead bulb of modern shape, and half size profiles. No construction details are on the drawings. Designed by Adrian Brewer.
$ 14.50
Order no.: MAR2395
POCAHONTAS
Reconstructed lines of the classic 1936 M class design by W.J.Daniels. Body sections shown fullsize with reduced lines for planking, and building notes. Designed by A Team.
$ 10.00
Order no.: MAR2489
