Anyone else noticing that it takes a long time (sometimes an hour) before threads are marked as read?
Hi Don,
Could it be that you are a slow reader???
Seriously, I just did a ‘mark as read’ test and it was done immediately.
You could try deleting your Internet temp files and delete the cookie for this site. Then try again.
Sorry, I didn’t phrase that right, I was referring to the automatic ‘marked as read’, like you read a post and 5 or 10 minutes later it should be grayed out.
By the way John I sat down and figued out IOM sail area and it is 925 sq in give or take a bit. Bigger than an “M”. What time will you guys be showing up tomorrow?
Hi Don,
I plan to be onsite by about 9:00am in case help is needed to set marks etc.
I will be at the McDonalds on the corner of Rutherford Mall for breakfast at about 8:30ish.
Hope to see you.
JOhn
