When I first joined this forum and mentioned that I had competitively raced both Marbleheads and Multihull’s, I was asked to comment on my thoughts of both classes.
When racing the Marblehead class I found that it was extremely dog eat dog. By this I mean that the rules as they stood then( fortunately these have been changed) where stretched to the limit. For example, on many occasions I would be on a gaining tack and call another boat on port and starboard. So that this other skipper would not loss his position he would call “out of control” which would then mean to prevent an incident I would tack, lose my advantage and then by some miracle his boat would “start working again”. As I said fortunately the rules have been changed to prevent this happening now.
The guys I raced against(with the above aside) were a competitive group. In this group were Australian champions and also other extremely experienced sailors who had been in the class for years.
The Marblehead, I found to be a very easy boat to sail, not that different to real boats in performance. Although it did require an amount of concentration, the lead bulb was of great assistance. By this I mean big rigs could be carried without to much trouble for longer than they should have been.
I competed with my boat at two Australian titles, without any success.
I left the class when most of the guys I sailed with went to IOM’s.At about this time I saw some r/c multihull’s being sailed and thought I’ll give them a go.
It was like starting all over again. My experience that I had gained sailing and racing Marblehead’s meant nothing when it came to skippering multi’s.
They are totally different.
The speed that is produced in the right conditions is unbelievable. The control needed is precise as one small mistake, and you are in the row boat picking it up.
I think that now after 5 years I have nearly mastered the art of sailing these boats, although changing designs takes you almost back to square one.
So to compare Marblehead sailing to Multihull sailing is impossible except to say that they are both sail boats. Obviously by sailing monohull’s you learn pointing angles and how to tack etc which helps in any class.
I do not believe however that people who have never sailed before shouldn’t enter into r/c multihull sailing as to learn from step one with a multihull will put anybody off.
This is just something that the r/c sailing scene in general doesn’t need. The more people enjoying our form of sailing can only be good for the sport.
