live chat
is it just me or is the live chat not working? it will let me log in and it will count me as being loged in and will load a black screen then go straight back to the log in aria again
do you use a pop-up block soft (maybe google bar?)…if so, try without!
what browser do you use?
I have troubles with a mozilla based browser…but IE works fine!
Wis
it was the google bar running ie removed it and it worked first time thanks
btw you dont need to remove the google bar…press CTRL when you login into the chat
Wis
