Interesting boat. Designed to the Universal Rule, so guaranteed to be pretty. Designed by William Gardner, the designer of the famous schooner “Atlantic” as a one-design class for members of the Larchmont, New York, and Manhasset Bay clubs. Rated at 35.63 feet under the Rule, between the official “N” and “P” Classes. Six were built by Wood & McClure of New York, and launched in the Spring of 1917:
“Varuna,” owned by James Ford
“Georgia” , Charles Lane Poor (author of “Men Against the Rule”)
“Celeritas”, H. Kendall Hester
“Mirage”, T.J.S. Flint
“Nimbus” E.P. Alker
“Grey Dawn” Philip Johnson (of Philadelphia).
Class symbol was an “L” inside a circle.
59 ft 10 in LOA, 38 ft 6 in LWL, 7 feet 10 in draft, 12 ft beam. 35,500 lbs. 1700 sq feet sail. Gaff, converted to Marconi by Gardner in 1926.
A one inch to the foot model would be about the size of an EC12 and displace 20.5 lbs. She wouldn’t be able to carry 1700 sq in of sail, so John Black’s trick of multiplying the linear dimension of the sail plan by .9 and then shortening the boom (to increase the aspect ratio and fool the eye into thinking the rig is taller than it really is) would take her down to 1100 square inches, which full-keel boats of that size (such as the 1920’s MYRAA D and R Class) were known to handle. That’s for the Marconi rig. If you left her as a gaffer I think she would be able to handle the 1300 sq in you get by just adjusting the linear measure.
All this data, and the lines plans below, from Edwin Schoettle’s “Sailing Craft,” the definitive work on yachts in the 1920’s. Reprinted a number of times, there are ton of them available on Abebooks (www.abebooks.com) from seven bucks on up. The book has photos, but unless you spring for the $150 up for the first edition they are too muddy to scan.
Download Attachment: [
lines1.gif](http://www.rcsailing.net/forum1/data/Earl Boebert/2004218205155_lines1.gif)
22.25KB
lines2.gif](http://www.rcsailing.net/forum1/data/Earl Boebert/2004218205225_lines2.gif)
16.57KB
gaff.gif](http://www.rcsailing.net/forum1/data/Earl Boebert/2004218205249_gaff.gif)
19.41KB
marconi.gif](http://www.rcsailing.net/forum1/data/Earl Boebert/2004218205324_marconi.gif)
4.74KB
