Hi Neil,
Maybe I did not make it clear before, but I’m now working with “new” hulls which are the same design as my old hull (actually coming off the same mould) so there are no issues of internal hull surgery to reposition fin boxes and reinforcements etc … so we are working with a clean bare internal hull at this time.
Further, I did not clearly explain that I have had professional carbon fins made, not homemade (I can’t make them light enough) therefore I can say they are as rigid as they can possibly with minimal flex. Profile @ 6% tapering chord.
What you’re say about maintaining the original boat balance centre points designed into the hull, when changing to another keel fin planform, makes sense.
The straight trailing edge keel fin is what I have on my old hulls, which have good “helm” balance (sail plan positioning) which I understand to be different from “boat” balance (mass distribution) I would like both to be the same or close to as my older boats.
Following your explanation, I have drawn up your description to see how a straight “leading” edge compares my original “trailing” edge fin while maintaining the hulls designed balance points:
1. Keel Fin centres same position ](grey dotted line) The “leading edge” fin requires to positioned further aft in the hull to maintain the same fin centres.
2. Bulb position same place ](grey dotted lines) Keel fin intersection point on the “leading edge” fin moves forward on the bulb.
3. COE same position for both fins. (grey dotted lines) We still have an increased distance from the leading edge fin to COE when compared to trailing edge fin …
Which brings us back to my original questions which are still not answered with our exercise here, but you have introduced some points that maybe lead to the answer questions 1 & 2.:rolleyes:
“I suspect most keel profiles are driven by connecting the center of lateral resistance portion of the keel to the midsection of the bulb and filling in the desired area, not for hydrodynamic ideals.”
I follow your suspicions, excepting the point of not following hydrodynamic ideals, I learnt from Claudio while building my first hulls that when it came to the Fin & Rudder that these appendage surfaces should correspond to 5.5 max 6% of the sail surface area this has been the rule I work with. If I have a larger surface area fin to have the same leading edge distance to COE, the knock-on effect as a result of this change will be more keel fin surface area which = more drag (slower hull)
Your valuable next point
“a boat involves not only an understanding of how the various balance points work together on several angles of heel, and all the other considerations that go into the hull, but the physical considerations to contain the various forces acting on the boat and appendages.”
This turned the light on :idea_125: into thinking about what Claudio did on his recent AC 100 build by having a adjustable keel fin (fore & aft) by 1% to “fine tune” this unknown variable.
Neil you helped answer questions 1 & 2 …THANK YOU !!
What affect does increasing distance of the “fins front edge to COE” have on boats helm balance? YES it will affect helm blance, but it is unknown
If helm balance is affected, how do you correct it? Fine tune keel fin fore & aft (Thanks Claudio)
So that just leaves just one unanswered question:
- What are the pro’s & con’s between these 3 different keel fin planforms ?
Hi Matt, You maybe right or wrong about fin shape …I don’t know, but let me ask a you question …Why have you built so many hulls to get to the rocket you have now my friend ? … I’m just what 4-5 new boat re-builds behind you ? maybe more :graduate: I’m learning as fast as I can to catch-up to you
