wim,
the 10 rater should look very nice when done,kudos to the open 60. my hat’s off to you. not too many rc sailors can build and sail their own.me included.(but at least i dont go around whinning about the cost;-)
regards
ed
just a few tips use packing tape on your forms so you can get the planks off it heaven forbid you need to with out destroying your forms. second clean of any excess glue as you go as its eiser to remove with hot soapy rags( if using pva) than it is to try and sand of after just a thought for next time just a thought from some one who didnt clean up gule as he went on a strip placnk sea kiack and i did use epoxy
wim
from one builder to another.
you should protect your frames. i use saran wrap(cling wrap) to cover all the frames. this aviods drips, spills and any other mistakes,( that might happen) i am pretty good a palnking. and there are spot where my planks do match up perfect. the saran wrap protects the frames. and when it come to making the mold. i like to see what the inside of the hull looks like. i finsh the hull. including the transome. then i make the mold.
i wish you good luck. and if i can help. email me
long live the cup
I just read your post on the MSN rcsailing group. And my compliments for building such a nice boat. But I have one question, the internal structure is made of balsa? Is it not a better idea to use plywood (or another wood a bit stronger than balsa)? (just a thought)
Because of the directional carbon I only need the balsa as support for the deck until it’s cured (since I will not make a mould for the deck, I think). I havn’t decided yet where and how I will install the winch and servo. This will help me decide what path to follow (I hope [:-captain])
