Here’s a hypothetical question to compare a standard IOM with an IOM CBTF, that?s fits within the measurements of the IOM rules, ie
LOA 1000 mm
Hull draft < 60 mm
Keel draft < 420 mm
Keel weight < 2500 grams
OA weight > 4000 grams
Sail area A, B & C rigs
Hull Measurements
(If someone can throw these figures into a hull design program to do the number crunching for wetted surface area etc would be great and even a vpp for each boat)
--------------------------------------IOM,----------IOM CBTF,
LOA------------------------------10000 mm,-----------1000 mm,
Beam max---------------------------240 mm,------------220 mm,
Beam WL----------------------------200 mm,------------180 mm,
Hull draft--------------------------56 mm,-------------40 mm,
(Pity that funnybones - oziomz.com has not got the information on the various IOM designs on his web page)
Righting Moments
There have been some assumptions in working out the following.
- The centre of buoyancy has been taken at 50% 0f the hull draft.
- There has been no allowance for the increasing RM as the hull heels due to the shift in CoB.
- Any thing else that I have forgotten!!!
----------------------------------------IOM,----------IOM CBTF,
Keel weight----------------------2500 grams,---------900 grams,
Keel draft
(centre of bulb to CoB---------------377 mm,------------370 mm,
Cant angle------------------------------n/a,------------50 deg,
Heel angle---------------------------20 deg,------------20 deg,
RM-----------------------------32,275 gf/cm,------31,292 gf/cm,
Weight Break down
Foil & bulb----------------------2500 grams,---------900 grams,
A rig-----------------------------275 grams,---------275 grams,
Hull weight
(includes rudder & servo,
sail winch
receiver & battery)--------------1000 grams,--------1000 grams,
Hull makeup weights---------------125 grams,-----------0 grams,
Front rudder & servo----------------0 grams,---------125 grams,
Keel drive unit---------------------0 grams,---------400 grams,
Total----------------------------4000 grams,--------2700 grams,
The IOM CBTF is about 1/3rd lighter.
The Race.
Since it is all hypothetical, the wind would of a consistent strength and direction so we can bang the corners on the wind. My guestimation is that the IOM CBTF would be faster as it carries the same sail area, same lwl, less wetted surface area, less displacement (1/3).
Ok guys go for it.
But no personal attacks please, just have great time.
