Hi John,
I like your interventions because are forcing me to see differently my own design. Thanks.
What do you think about Open 60 or VOR ?.
Why, according to you, the next America Cup boats should look like this sketch ?
My “bet” is to copy and elaborate around these designs. All these concepts have almost no rocker and the bottom is rather flat.
Some pictures of VOR and Open60 ‘seen’ differently :
Here, the mast step is closed to the fin beacause the CE is rather advanced due to to the large jib surface. Notice almost no rocker ! Very often the CE is closed to the mast as for the IOM model, therefore closed to the fin .
the same boat seen under :
A VOR type :
Another one :
Everybody knows that this type of hull is very fast in all points of sailing except in “close hauled”. In my opinion, one could win a race exploiting the reaching caracteristics.
Still remain the question :
Why America Cup AC33 boats, racing in close circuit (banana), should have choosen that hull shape ? Actually nobody knows what will look like the next AC boats !
My model, without pretending, will try to bring me some answers to my many questions, the simplest way is to design and make it. As said before, if will be a total fiasco I will tell it.
Being uncertain about, the mast position will be widely adjustable in order to cope with various sail design and surface"s ratios I have in mind . The fin/bulb are positioned under the CB and only one rudder is used but positioned more close to the fin otherwise will go out of water at 30° of heeling.
John, according to your experience, have you an idea of what could be the right proportion between main and jib in relation to the sailing points ?
Many Thanks
PS: My FUXIA way of looking at
