GPS
angus
I don’t know if speed measurement is accurate enough ( most probably it should be mentioned on manifacturer specifications ). I hope so.
About the “frame time” it seems to me that it can be adjusted in order to reduce battery consumption - if needed -
My garmin seems to show very quickly changes of speeds ( within 5 sec )
In any case :
drag and speed should be measured on stationary condition, on a long and straight run, so this is not a big problem.
IAnd, if needed speed can be measured as space/time between two buoys at fixed distance
Fin & Rudder
andrew,
On modern yacht ( not long keeled ) it is very easy , and useful, to split hull and appendages properties.
extensive investigations have been carried out on :
different hull shapes - using exactly same keel and rudder -
different keels , on same hull + rudder
different rudders , on same hull + keel
In order to tow a footy with heel angle and leeway, unfortunately a “test tug” should be much much bigger than the model.
Almost a real size dinghy ( may be this another “germ idea” )
The lift force on footy keel should be considered as a “floating rudder” moving tug stern to on side, and such force should be counteacted by rudder opposite force in order to have a straigh line course.
But there is another possibility : The electric test footy
removing the rig, and installing a motor driven air propeller not far from sail center of effort and rotating such “thing” in order to generate driving force as well side force ( an electric sail force ! ) model beaviour will be very close to a sailing one.
testing several keels , with same engine setting, and measuring time on a fixed distance it should be possible to investigate keel performances under “almost” correct working condition , and with a “scientific procedure”
A fore and aft propeller force shall be considered ad an “electric downwind”
As far I know this idea has already been tested
A lot of nice ideas for this winter
Flavio
Folgore ITA 5
ps :
a shot of the unsuccesful italian garden test tank
and a sketch of the “electric footy”
