With regard to the Fast Frank/Ljungstrom yoke, my setup is similar, except that it has also been calibrated for angular deflection of the tow bar. So far, I have been using the angular deflection, since results can be gotten from a single tow, to a sufficient accuracy. It also has the capability to slide the attachment points (using rubber grommets) for more accurate measurements.
Brett has mentioned towing in a stream. This may be a good idea, depending upon the uniformity of the flow. I was looking at a small local stream this morning, and watching the bubbles. It appeared that the bubbles were traveling at a constant velocity across a reasonable width of stream. But I was wondering whether this is really the same as towing in still water, since the stream has turbulence induced from friction with the bottom, as well as the previous history of the flow. Of course, the “still” water that we sail in has also been strirred up by the wind, so this may be an irrelevant concern.
A question for Brett: have you found that the Hullform program is reasonably valid at the very low Reynolds numbers where we are working? I would suspect that it works for skin friction and wave drag, but not for form drag. Of course, I could be completely wrong.
