Hi Lester
Yes you are right , we are becoming obsessed with LCB and LCF movement . As you point out we know that in practice that when a boat is being heeled excessively and rounding up, that moving the mast and consequently the CE forward restores the balance .
This would tend to indicate that the boats centre of pressure has moved forward when heeled. Presumably this is a function of the centre of lateral resistance. If this is so then ignoring any dynamic effects it will be the centre of area of the heeled immersed volume ( LCR) as seen in profile.
To me it would seem reasonable to assume that when the bows pitch down , the stern rises and that this profile area will pivot about the LCB. The centre of this area ( LCR) will then move forward thus reducing the essential lead and requiring the sail’s CE to also move forward for balance to be restored.
Conversely if the bows were to pitch up on heeling , then the LCR would move aft with the opposite effect. Is this what is happening ?
Is this why by having no pitch forward on heeling with the LCB and LCF staying in the same place causes no LCR movement , and hence no round up ? Certainly it seems that boats that are balanced in this way behave well .
If this is the case I can see that a small pitch up in a gust as a boat heels would help as the effect would only be momentary and would counter the natural tendency to round up by increasing the lead distance between the sails CE and the hull’s LCR, effectively applying a touch of weather helm . Isn’t this exactly what we do to counter the problem .
Maybe by having the LCF move very slightly forward on heeling we are actually keeping any LCR movement under control and in a positive direction. In other words is controlling the movement of the LCR the real issue and LCF movement is just a means of doing this by controlling pitch on heeling ?
Anyone have any thoughts on this , or am I talking rubbish
John
