Just when I thought I might be getting a handle on this , I was looking on the Boat design forum and found a thread about "rounding up to weather in gusts " and what do I find but
[i]Originally posted by Stephen Ditmore
I think the method referred to by Coozeman is the same as that discussed by designer Cyrus Hamlin in his book “Preliminary Design of Boats and Ships”, pages 195-197. His method is to calculate heeled LCF (center of the waterplane) at 30 deg (25 deg for flat bottomed/shoal draft hulls) without allowing the hull to retrim from static upright trim. He then takes the distance between the upright and heeled LCF’s as a percentage of waterline length. Hamlin recommends that the LCF should shift aft as the boat heels, but the shift should be less than 1% of DWL.
Cy Hamlin was a lecturer at The Landing School when I was there, and explained that his method was a simplified variation on the method referred to by Ian Ward involving wedges of sections. BTW thanks, Ian, for the reference concerning the term "metacentric shelf.
This is the exact opposite !!! seems hard to believe
I dont feel comfortable with their argument , as with models anyway it’s the ones that bury their bows in a gust that seem to have the problems , so I can see how the bow lift with a forward LCF shift would help and a rearward shift would cause to bow to sink in and make it worse. Regardless of any effect on the heading they don’t steer well with the stern in the air!
I have a boat which is a real dog at this sort of behaviour so I might see if I can recreate its lines in Maxsurf and then do the cardboard cut out heeled waterline trick and see what it’s LCF shift is ! If nothing else it will show me what not to do .
I made an error at the transom when doing the heeled waterline area plot. When I corrected this I got a forward shift of the LCF of 10mm or 1%
One percent of the DWL would seem about right as this is about what I have used when moving the keel to retrim and it gave a slight bow up trim , but nothing radical,so wouldn’t hurt at all to have the bow lift by that much on heeling .
I wonder if anyone has ever collected the hydrostatic data on various designs and compared the correlation between LCB, CF positions , the shift of these when heeled and the actual on the water sailing characteristics ?
As you say the next step is to build it and see.
cheers
John
