Hi Anders,
I thought about bungy attached to the hatch idea you have out-lined, only problem I found was when you want to open the hatch, the bungy keeps the hatch cover around the hatch area, making hand access a bit of pain.
I’m from the dracon camp, the only initial problem I had was when you peel the dracon back to open the hatch that you can peel paint off also, to avoid this problem I now cut slightly larger patch & cut out hatch shape, kinda works like a gasket, then stick the hatch patch on top and no more paint peeling.
Dracon patches used this way can be used multi number of times (no need to have new ones all the time) providing when you take them off you put them back onto wax proof backing paper and keep the gasket surface dry when sticking patches back into position, otherwise it will not seal.
I have 3-4 patches on most of my boats to access to various areas if I need it for repairs etc. but I only ever take ONE patch off for changing the battery, here I put the battery in the boat before I leave home & rely on waterproof switch for turning power ON/OFF during the day … just need to remember to turn power ON when boat goes back in the water …had few occasions swimming after my boat …believe me, you learn pretty quickly through experience.
I’ve experienced no problem with Dracon, it’s easy, quick and 100% waterproof.
During the day condensation builds up inside the hull and if you have water ingress you need a simple & quick drainage system. With each boat I build I put 6 mm hole in the deck at the bow and use silicon bung.
Sailing in salt water waterproofing electrics is critical, I have seen how black rot slowly eats cables and runs into lot of head scratching trying find the problem that you cannot see. Seal all wire connections with silicon then put heat shrink tube over all connections.
Medical pots being round are little awkward for AC 120s, here I found square tooth pick plastic box with clip lid works perfectly and I’ve built it into the keel bridge so can slide it out of the hatch, if needed.
Cheers Alan
