Hi:
My name is Julio and I´m from Spain.
I want to learn much about of the “footy’s”
Excuse my bad english.
I have a footy and am in the process of making a better one. My suggestion is to a practice boat first then make a better one later. The hull is cheap to build I spent less then 10 dollars building my first hull the new one will be even less. Use stuff from around your house i found some 1/36 plywood, lead and fiberglass resin in my garage. the electronics are were you spend your money I spent 80 dollars on two servos a controller and receiver.
