This post reports on some investigations I did into finding a replacement for lead as ballast in small model yachts. Lead is bad news, especially for the young. It must be ingested in order to poison you or yours, but that can happen through inadvertent transfer from hands or clothing. Even if you are careful about your hygiene, the act of melting lead generates lead fumes which you can easily inhale. In any kind of a school setting casting lead is pretty much out of the question these days. Trying to explain the intricacies of lead exposure to a nontechnical parent whose only knowledge of the subject comes from news reports of toy recalls is not a task that I, for one, would look forward to. It’s much easier to be able to assert with confidence that no exposure is possible.
First, some numbers: lead is generally described as having a density of 11 grams per cc. This is an ideal number; the sort of scrap lead we usually deal with is more like 9.5-10.5 g/cc depending on what it is alloyed with. The closest solids that are economically within reach are the copper alloys, which run roughly from 8 to 8.5 g/cc. The disadvantage here is the effort required to shape the material, especially if a bulb keel is desired. I designed Yankee III to be ballasted by bricks of 1/2 x 1/4 in scrap copper bus bar, which at the time of writing was cheaply available. The price has risen sharply since then.
The next thing I looked at was using a rubber mold to “cold cast” a bulb from resin loaded with some heavy but safe metal. In the case of the student program I’m planning I really want to have the students cast their own ballast so they can go through the process of weighing the finished boat and calculating how much it would take to get her to float on her lines. This eliminates raw lead shot or “geezer cast” solid bulbs as candidates.
After some searching I found three materials that are readily (in the US, at least) available on the net: steel shot, copper plated lead shot, and bronze powder. The shot runs $2-3 a pound and the powder about $12 a pound. I weighed 50 cc measuring cup with various mixes. The inhomogeneous mixes were done by the Martini Method (shaking the ingredients together in a jar), and this is what I got for densities:
#6 Steel Shot (0.11 in/2.8mm dia): 5.5 g/cc
#7 1/2 copper plated lead shot (0.09in/2.3 mm dia): 7.1 g/cc
Steel and plated lead shot mixed: 6.6 g/cc
Plated lead shot and bronze powder mixed: 7.3 g/cc
The weighing was done dry; the addition of resin will reduce the density to the degree that the casting is “overloaded” with more resin than is absolutely necessary to bind the material. The result for the shot/powder mixture is promising. A bulb made from this material would only need to be 10-15% larger in linear dimension than a one cast from solid lead.
As a final experiment I attempted to see how much bronze powder could be packed into the plated lead shot by using my scroll saw base as a shake table. The resulting density was 8.5 g/cc, right up there with solid copper alloys. This was a pretty solid mass, and I doubt that enough resin could penetrate it to make a strong solid; so the preliminary result is that it’s only practical for filling bulb shells such as those Nigel makes, using heavily thinned resin as a binder.
So, in the interest of spreading the boundaries of Footydom (“The Sun Never Sets on the Footy Fleet?”) it would be nice if some supplier would package plated shot and powder in, say, 200 gram kits and made them available to those who would rather not hassle with lead. Cold casting a filler into a pre-made shell involves some cost in frontal and wetted area, but I think that in most cases this will be more than repaid by the ability to get such a small boat to float precisely on her lines.
