Getting our radio gear set up with LFP cells
I looked into what you’d need to hange over to the LiFePo4 cells in the typical model yacht.
You’ll need a 6.6V, 2100MaH receiver pack ($40) Will receivers and servos work on 6.6V?
Example: http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXDVCC&P=7
A 9.9V 1500mAh 1C pack for the Transmitter ($40) My Futaba 4NBL has a 9.8V pack, so that should work fine in that. Example: http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXAEBY&P=7
I’m not sure about which charger I’d use, but a DC dual-charger is in order because I usually top-off things in the way to the pond. Single-pack chargers start at about $70.
So Ou’ll need to spend about $150 to get the first boat working on LiFe cells. I would presume that prices will come down slightly as the cells improve or get popular.
Is there anything I’m missing besides a balancer? Any dessent?
thx
I came up with this idea because my tugboats use Lead-acid batteries, and they don’t last long in storage.
I have been using 1100MaH batteries for my receiver pack and seems to work OK. The battery is smaller and lighter than the 2100 size and I can fit the battery and Spektrum marine receiver in a sailsetc pot.
Dave
