Andrew
I really am in favour of conventionally shaped yachts, but a Footy that is 14mm (1.4 cm or 9 / 16ths inches) wide seems more like a knife than a boat. I thought my Phinn-ichthy at 95 mm was thin, but you have outdone me again.
Rod
p.s. Our water here is still frozen, with at least a foot (30.5 cm) of snow on top of it.
Had some conventional progress over the weekend - got Sloice assembled, but not waterproof yet - no base on the hull yet
Good news - the AA cells fit perfectly into the Sloice hull - That is, of course why it is 14 mm wide.
Less Good news - none of my steam receivers fit into the 14mm space. I will, when time permits, sketch the layout but in words:
The middle of the hull is an open well/fin/mast box where these components are adjustably disposed (thank you Gary). Batteries live 2 ahead, 2 behind the box, Rx above the forward 2 batteries, servos screwed to the “decks”. Rudder servo is immediately ahead of the “transom”, sail servo somewhere ahead of that.
Rudder is hung on two dismantleable r/c aircraft hinges and will be 1/32 ply core with balsa sandwich each side.
Macrig, of course.
It is JUST possible that some more flotation may be required, Sloice will therefore acquire a pair of “bustles” attached (velcro or magnets) to the flat sides. These at present are being refined in shape in a secret location using FEA, CFD and TLAR techniques.
some pics of her attached - I believe that when fully watertight she will be the boat to beat in the Dead Sea footy racing.
Today I have learned also that Sloice is bent - not as much a N Khan - but nicely banananaed. I will have to rectify this, but at present she would be unbeatable at Oval circuits.
Shipfoot hull is moulded and dried out - this is the first time that I have done papie mache using emulsion paint* as the glue/bonding agent. I have put on about 5 or 6 layers of ordinary newsprint, and the hull is leathery - but not crisp and stiff.
*I think this mat be what our US brethren (and sisteren) call latex paint. Its waterbased, low odour, fast drying and used for indoor large surfaces.
Not sure what I expected, but I can live with this and take steps to waterproof the paper (the emulsion paint is waterproof anyway)
Hull weight in this stage is 25 gms or close - which isn’t too bad for a box-filling hull.
The first three layers are bonded with gold emulsion, the next three with orange stuff - guess who is using up 10 year old matchpots?
She is properly cod-headed and mackeral-tailed, you will observe. Wonder if I could claim “scale” points?
