Hi folks,
After a couple of evening chopping depron and a little balsa and ply I have a hull ready for fitting out
It’s a slightly skinny Razor I and is looking to have a Ranger(esk) Aero-Lateen rig (keeping it simple for a first attempt).
Hull is 2mm depron (taped and epoxied) with 6mm deprom mast/keel support, keel is 6mm balsa and rudder is 0.8mm ply core with 2mm depron cheeks. Spars are 3mm carbon tube. Sails to be sorted, probably ‘bin liner’ for a rough and ready first cut, and most likely some 65gsm ‘rip-stop’ I have just located for a final set.
I am thinking of a 3.5grm servo for rudder (the blade has plenty of lead so is near balanced) with a 12mm BB/MG for the rig.
Fair winds
